jbgood
Member Since 18 Dec 2013
Offline Last Active Dec 30 2013 04:21 PM
In Topic: LG refrigerator ER FF code
21 December 2013 - 04:50 PM
I did installed a new fan but it never worked. Subsequently I discovered that the main board is bad, so before I install the new PCB I would like to test the fan but don't know any procedure for testing. Can you help with a testing procedure?
21 December 2013 - 12:11 PM
John thanks for the information it was very helpful, I ran the test that you recommended and found that the board is defective, no power the fan. in fact I found a burnt chip right next to the Con7 plug marked Q6. What should I be testing before I install the new board?
18 December 2013 - 10:18 PM
Thanks for the response BryanS. When I took the panel off the back wall to get to the fan there was no ice buildup, it all looked normal except the old fan was not spinning.  I will have to make a decision soon.
