denrayr
Member Since 29 Mar 2005
Offline Last Active Yesterday, 10:35 PM
In Topic: Subzero 690 service light
14 November 2013 - 03:04 AM
Ken, it is common for the freezer compressor relay to stick on these models. In this scenario, the compressor runs all the time, even during defrost. The end result is an evaporator encased in ice. To test the relay, push the on/off button on the control panel to shut the unit down. Listen for the freezer compressor. If the compressor continues to run, then the control board should be replaced.
In Topic: GE Monogram mess
05 November 2013 - 05:27 PM
There is an air damper located in the top of the fridge behind the light covers. Remove the damper and check to is if it is physically broken. If so, you have found your problem.
In Topic: LG Double Oven F19 - can't use both ovens at the same time - Model LWD3081ST
05 November 2013 - 01:09 PM
Thank you
Is there a specific way to test the radiant heater?
You can use an ammeter to check the amp draw. If each oven works by itself, but not together, the first thing to check is to make sure the connections in the junction box are clean and tight.
In Topic: GE Gas Range JGBP90MEB3BC Broiler not burning clean
05 November 2013 - 01:05 PM
These types of burners generally use a hood type of orifice. There is a pin behind the orifice. When you tighten down the orifice, the pin restricts the flow of gas. For LP, these hood orifices should be tightened down to their limit.
In Topic: LG Fridge LFX28978ST /01 Problems
05 November 2013 - 01:01 PM
Grab an ohm meter and ohm each wire in the disconnected harness to ground. Based on the damage, it looks like the pillar heater circuit is shorted to ground.
