alanlee
Member Since 26 Jan 2014
Offline Last Active Apr 18 2014 07:46 PM
In Topic: SHX5AL02UC06 Bosch Dishwasher Starts then goes to clean without washing dishes
18 April 2014 - 01:20 PM
Not really interested in throwing $180 on this this problem to see if it fixes the problem.
It does seem strange, that I can always get it to run 100% thru the customer service cycle and not show any problems....I am using that to clean dishes for now.
How can a pump work some times and not others...?  I keep trying to hang on and get a hard failure, but remain in this limbo state where it seems like everything is working, but it just goes from start to finish in 5 minutes and says it is clean.  Seems like some sensor or something is telling it to stop....I did adjust my drain hose to smooth out the turns it was taking after the hose exited the dishwasher...that and the drain pump got me working for about 2-3 weeks.
Frustrated and ready to toss this one.
13 April 2014 - 11:24 AM
after about 2 weeks of success after replacing the drain pump I was ready to declare victory...
but alas...today I started to get the exact same symptoms.
It starts up and then goes to clean without filling with water or anything.
I heard from a neighbor that he had a bad motherboard and it was
replace for free because it was less than 5 years.
 I do not see a motherboard listed as a part, so I do not think it is that.
Any other suggestions would be helpful.  I am ready to dump it and buy another brand.  Kenmore comes to mind.
Fed up with Bosch.
24 March 2014 - 07:10 AM
Ok, I will do that, but why does this pump error not show up during customer test program?  Just seems odd.
In Topic: SHX5AL02UC06 Bosch Dishwasher will not fill. Starts then stops after 5 minutes
01 February 2014 - 03:01 PM
An update.- Dishwasher has been working all week. Ran at least 7 times.
Went to level it out, since I had it in an unlevel position while I was debugging and it did not run after I leveled.
Went back to having the rear about 1/2" lower than the front and it ran!.,...what would cause this?
28 January 2014 - 10:02 PM
I ran the customer service test program and it filled the tub and heated the water  I got a 00 error code...indicating no issue.  Think I will cross my finger and hope the issue has been solved.  If does happen again, I know how to run the test program and get further along on the trouble shooting.
Thanks for the help
