BornABruin
Member Since 14 Dec 2006
Offline Last Active Jun 06 2013 12:42 PM
In Topic: Kennmore Trio - Freezer OK, Fridge warm
04 June 2013 - 04:05 AM
I thought I would close out the tread -- it was the Evaporator motor.  I replaced the motor and all is well with both the refrigerator and freezer again.  Thanks for everyone's help!
I have a new problem with a dedicated chest style freezer, but that is a problem for a different thread...
14 May 2013 - 07:36 PM
I forgot to close the door switches.  On the other hand, I did give the fan a push and it did start turning, but not at any significant speed (at least not enough to push any volume of air up into the refrigerator.
Unfortuantely I do not have a schematic -- it would have been useful here to be sure.
I believe the Door Switches need to be closed.
Will the Evaporator Fan run at all if given a "push" ?
Is that one of those Amanas that use the Defrost Bi-metal in the Evaporator Fan circuit ?
Does the Defrost work OK ?
Do you have a wiring diagram you could scan & post ?
13 May 2013 - 04:43 PM
I'm not sure if the fan should run when the doors are open, but I did try the two door switches.  The lights turned off but the fan still didn't run.  I'll try to post a picture of the frost pattern tomorrow morning.
a picture of your frost pattern would help.....does the fan turn when you keep the light switch pressed in and/or the bottom drawer closed? You have no idea how many times I think.."oh the fan isn't working"...then I remember to press the light switch or close the doors.
