fixandsave
Member Since 15 Dec 2006
Offline Last Active Oct 25 2012 12:33 PM
In Topic: Need Tip for Installing Washing Machine Belt 417.39022890
24 October 2012 - 11:33 PM
Thanks guys. Ziptie worked!
24 October 2012 - 11:18 PM
Apologies but I do not understand. Ziptie the belt to the pulley I believe is the easy part. Once I have ziptied it, do I then turn the pulley so the rest of the belt catches?
In Topic: Dishwasher Miele Incognito G843
29 August 2011 - 09:40 PM
I finally got out the return valve and made sure nothing is stuck. I even disconnected the end of the hose that goes into the sink, had a wet vac suck the remaining water from the dishwasher. No clogs.
I ran the dishwasher again. I can hear the water fill. Once done, it goes silent. No swishing water. After about a couple of minutes from when I started the dishwasher, the light flashes (Intake/Drain) flashes again.
How can I trouble shoot this Miele machine?
Help!
18 August 2011 - 03:50 PM
Return valve is stubborn. Any other suggestions? I suspect water deposits caused it to be stuck. Has anyone had similar issues before?
07 August 2011 - 07:35 PM
I need suggestions on how to pull out the return valve. Seems stuck due to hard water deposits.
Please see page 51 on this operating manual.
Operating Manual
