FAQs | Store | Memberships | Repair Videos | Boot Camp | Newsletter | Beer Fund | Contact
fixandsave
Member Since 15 Dec 2006
Offline Last Active Oct 25 2012 12:33 PM
Need Tip for Installing Washing Machine Belt 417.39022890
24 October 2012 - 10:16 PM
I have a front-loading Frigidaire washer 417.39022890.
I am having a tough time reinstalling the belt. I would appreciate any tips.
I have attached a picture for reference.
Thanks in advance. Dirty laundry is fast piling up ...
Suspension Spring 417.39022890 May have Snapped
23 November 2011 - 01:30 AM
Is this possible? Late in the wash, I heard this loud thud. Once the wash was finished and upon inspection - I did not run to it immediately - I noticed that there still some water in the tub and one side is no longer hanging by the spring. I looked through the inside by removing the front panel just below the door.
I have not gotten to it yet but is it possible that the spring actually snapped? If so, what is the correct part number so I can put an order in asap.
Thanks!
Dishwasher Miele Incognito G843
07 August 2011 - 04:47 PM
The Intake/Drain indicator flashes and the dishwasher stops working. Water stays in the dishwasher. The manual suggests cleaning the drain pump. This is where I need help.
I tilted the clocking clamp to the side but cannot pull out the non-return valve to get to the drain pump. We have hard water - perhaps this has something to do with difficulty in pulling out the valve.
Any suggestions?
Frigidaire Dryer 417.59022890 Leaves Brown Marks on Clothes
06 May 2010 - 05:55 AM
The dryer leaves brown marks/stains on some clothes.  I could not tell where it is coming from until a piece of clothing was left stuck to the front part of the drum after the drying cycle.  I pulled out the clothing and sure enough it had a brown stain on it.  I also ran a small piece of cloth around the drum and got the same stain.
1. How do I fix this problem?  Does it require a new part?
2. Where can I find instructions on how to disassemble the front part of the dryer?  I cannot locate a forum entry on the same exact dryer.
Thank you.
Amana Refrigerator ARB2557CSR/PARB2557CS1
07 July 2009 - 09:17 AM
My refrigerator ice maker arm shut somehow got disengaged.  Since I never observed how it was installed in the first place, can someone please tell me how to install it back on?  Right now I believe the unit is in the OFF position.
Thanks in advance.
PS. There's a warning on the unit not to touch it!
