ciucca
Member Since 22 Jun 2005
Offline Last Active Jul 10 2014 08:53 AM
In Topic: KitchenAid kudc20fvss Drain for a few seconds and stops
29 February 2012 - 05:43 PM
Thanks for the advice, but.. I just went back and pulled the rubber check valve under the chopper housing. Turns out there was a pistachio shell stuck behind it, and it was also gunked up pretty good. I removed it ran the drain and all the water pumped out. I put the rubber check vavle back and still works, drains completely. No one in my family ever rinses their dishes before putting in the DW, so I guess I will know what to look for the next time this happens. I truely feel like Homer, time for a Duffs!
Thanks for the quick response.
In Topic: Jenn-Air WW27430P Food Tempature Probe
21 November 2009 - 09:57 AM
I finally had the time to check everything, and I have a bad probe jack.  Does anyone know the part number for this?
Thanks.
17 November 2009 - 05:04 AM
Thanks.  I will try that.
In Topic: Jenn-Air WW27430P oven will not unlock after self clean
23 September 2009 - 12:21 PM
After some jiggering I was able to get the connector through the hole and replaced the oven sensor without splicing the wires.
After putting the new one on all is well for now.
Thanks again for all your help!
21 September 2009 - 04:27 PM
Thanks!
I will use the ceramic wire nut method since I am not interested in pulling the oven from it's mount.:D
