Use EEPs to Troubleshoot This Circuit Entirely from the Control Board
I covered troubleshooting 240 VAC heater circuits in a previous post, but I wanted to revisit that topic with a more specific focus: can you troubleshoot an inop electric heater entirely from the control board?
Why is this useful to look into? Because in real-world troubleshooting, avoiding unnecessary disassembly is key to quick troubleshooting and avoiding liability. This makes finding Electrically Equivalent Points (EEPs) for your electrical test points eminently practical.
Let's look at the circuit in question and get our bearings.
Circled is the electric heater we're interested in. It's a dual element, so we actually have two parallel heating elements. That's a good thing for our plan to troubleshoot entirely from the control board -- it helps us do that!
Let's look at the heater's circuit.
Our heater needs both L1 and L2, like all 240 loads. These two legs of the power supply pass through a few controls, which we need to take note of:
In the L1 side, there are two thermal switches -- the inlet safety and the outlet control backup. In the L2 side, there's the centrifugal switch.
A quick note on the centrifugal switch: notice that there are two electrically separate switches circled, both of which are centrifugal switches. One is in the motor windings' circuit, and it's normally closed. The other is in the heater circuit, and it's normally open. Both of these switches are actuated when the motor starts spinning. We're only interested today in the normally open centrifugal switch in the heater circuit.
Great, we know how our heater gets its power supply, and what controls that power supply has to get through to reach the heater. But what about starting by testing the heater itself? Can we do that from the board?
We sure can, and it's thanks to the fact that we have a dual heater. If we read from one of the heater relays on the board to the other (while the machine isn't running, of course), then we'll read through both heater coils, like so:
Even if we don't know the exact resistance spec for the heater, as long as we don't read a very high or infinite resistance, we can say with reasonable confidence that the heater is okay.
Now what about all these different controls in the heater's circuit? We can test those from the control board, too!
Let's test those two thermally controlled switches in L1. All we have to do is check from one of the heater relays (doesn't matter which; we just pick one) relative to Neutral.
This test is done without the unit running. If we have 120 VAC on our loading meter, then we know we have L1 at the relay, and that means both of those controls are good. Simple, elegant, and requires minimal disassembly!
So that's L1 sorted. What about the L2 side of things?
For this one, we first disconnect the heater connection from one of the heater relays (again, we just pick a relay). Then, we start a cycle and check from that wire we disconnected to Neutral.
With the dryer running, the centrifugal switch in the heater circuit will close. And with the wire disconnected from the relay, there's no current flowing through the outer coil. This means that L2 will be present right up to the wire we disconnected. So if the centrifugal switch is good, we'll read 120 VAC on our loading meter, since we're reading L2 to Neutral.
And just like that, you can check the heater itself and every switch in its circuit right at the control board. How much testing you can do this way depends a little on the exact machine you're working on. This one had circuits that are particularly amenable to troubleshooting with EEPs, but you can almost always find at least some clever tests at more easily accessible points, no matter what you're working on. The key is to look at the schematic beforehand and analyze your load of interest and its circuit, just like we did. Practice that, and soon the EEPs will start jumping off the page at you.
- Appliantology.org is a cultivated, private community of techs.
- Get solid tech advice from working, professional techs and business owners.
- Avoid the endless noise and guesswork thrown at you from groups on social media.
- Download the service manuals, tech sheets, and service bulletins you need to git 'er done.
5
2
6 Comments
