  • entries
    862
  • comments
    1,398
  • views
    2,717,976
Unlocking a Stuck Door on a Maytag Whirlpool Alpha Platform Front Load Washer
In this scintillating safari into front load washer wasteland, Samurai Appliance Repair Man shows you how to manually unlock the door on a front load washer with the door stuck locked. This particular kata is for the Maytag-Whirlpool Alpha 2 platform front load washers but the same technique can be applied to most other models.
To order parts, call our parts department at 877-803-7957
2 Comments
applianceman97
Early alpha washers have the manual unlock tab on the bottom of the lock like the duets. Makes it a little harder because as we know there is no bottom panel. i don't think many left the factory with that type of lock though. What PITA to reach it.
