Learn how to troubleshoot using schematics like a real tech…
    7
    41
    6,222
The importance of high efficiency soaps in modern washers
AlboGator
So I’ve been reading lately and see there is a lot of mis information floating around the web on the use of standard vs high efficiency soaps in modern washers. I’ve seen articles stating that the phosphates are the only thing missing from the soaps and they are fine to use to others saying that the only difference is they are less sudsing and the suds can interfere with the movement of the clothing inside of the washer. Then there’s the absolutely incorrect idea that you can use less regular detergent as well and it will serve the same purpose.
While it is true that they are low sudsing it has more to do with the water tension and the ability of the water to pass through the fabrics to remove the crud. After this crud is removed the detergents job is to suspend said crud in the water to be drained away via the drain pump, in the process not letting them redeposit on the clean clothes. The phosphates have been removed because of algae blooms, nothing to do with the washer. This was more of a problem with dishwasher detergent, not clothes washers. Remember the calls of "My dishwasher doesn't wash as well as it used to" a few years ago?
There is a chemical difference in the soaps being made today. From my less than basic understanding of chemistry I get that soaps are traditionally lye based where detergents are formulated chemicals. High efficiency is made to be able to suspend dirt, dye, oils and all the crap in your dirty clothes in low volumes of water where traditional soaps will not work because they require a high volume of water to work. These new machines are generally using 12 gallons of water where the old types would be around 56. That’s a pretty big difference.
Something that is extremely important in selecting your soap is to be 100% sure that it is real high efficiency soap. I’ve been seeing soaps with the he logo on them that in the fine print say “safe for all machines, including he” and I think this is a downright dirty lye. (See what I did there?) Although it may not be lye based it’s still not real high efficiency and a bearing burner. A recent tour of my local walgreens showed me that an estimated 80% of the detergents there were labeled "safe for all machines".
There are a couple of things that are being observed in the field regarding the use of high efficiency vs conventional soaps.
1. Non high efficiency soap in he machines will cause you problems
2. Using the wrong amount of detergent in he machines will cause you problems
We have all seen multiple problems arise from people using standard soap in their high efficiency washers. This is what I've noticed.
The first and most obvious is how the suds are damaging to the drain pumps. Excessive suds in the drain pump can make it run longer than it needs to run and severely shorten the already short life span that these overpriced Chinese motors are shipped with. The machines can think they still have water in them because the suds interfere with the drain process and can also trigger the water level sensing devises making the pumps run even though the washer has fully drained. This overheats the drain pump and essentially damages it a little every time that happens.
Second are the expedited failures of washer bearings, both on the front load models and on the newer top load agitator-less and fake agitator washers. From experience I’ve seen front loads last for 12 years with moderate use using the correct detergents. I’ve also seen front loads last for 5 years with low use using regular soaps. In the short lived cases they were all using regular soaps or the stuff labeled “safe for all machines including he”. Over the last year I’ve seen multiple top load whirlpool built VMW's and at least one LG with gear cases needing replacement because the bearings have failed. This starts out with a noisy spin and eventually an “out of balance” code. The out of balance will not go away no matter how much redistributing of the load you try to do once it gets bad enough. Some of these were only 2 years old.
Slime, sludge, mold and gookus build up is another issue. Although all of these front load washers are prone to having a mold forming around the tub boot, slime will form on the outside of the inner tub and inside of the outer tub using non high efficiency soap. Using too much soap seems to make it worse. This is what causes the washers to smell like a high school football team locker room. It seems that this problem is getting better with the use of the correct detergents and I personally think the detergents have gotten better since inception but you have to use the correct soap and the correct amount. You can use the clean washer cycle with affresh every week but it’s not doing that good of a job anyway. It’s more of a “way to maintain it” feature than a clean the washer once it gets the buildup.
The point of this is that non he soaps are both causing us to make money (service calls) and not be able to make money on repairs at the same time. When the machines bearings burning up it's a condemnation on the washer most times. The only exception to the rule I've found is the original cabrio washers. I can change the bearing and the suspension and make decent money from the job, but other than that the vmw's and front loaders parts are too expensive to warrant a repair. In the former case the customer could hesitate to call us again for a repair. All it takes is a "her friend said that we went out and charged them to tell them to get a new washer". Although that's completely reasonable it can be a black eye to us and a deterrent for future calls. Prevention to those who will listen can help to preserve our trade and also help to establish it as a value for making their appliances last longer than their neighbors.
3 Comments
Excellent article, Walter! Great info for consumers and techs alike. A couple of additional points worth noting:
- Lye-based soaps make high pH (alkaline) slurries that are corrosive to machine internal parts such as drum support spiders and bearing seals. Also, their "cleaning" action is primarily through this corrosive process where the clothes are essentially "corroded clean." With engineered detergents, on the other hand, the bi-polar (hydrophobic-hydrophyllic) molecules grab on to the soil particle (via the hydrophobic end) and then get flushed away in the drain cycle (via the hydrophilic end). Completely different washing chemistry.
- In addition to causing problems with pumps through cavitation, excessive suds can induce other problems such as clogging pressure sensing tubes with detergent residue (dried suds) making the washer think the water level is too low. This, in turn, can cause the control to throw low water fill error codes or overfilling.
Share this comment
Link to comment
Thank you for the input Samurai. Always appreciate the understanding that comes from it.
Share this comment
Link to comment
Damn good research,  Excellent written words.  You make Durham proud.
Share this comment
Link to comment
