Learn Circuit Fu, the ancient lost art of appliance repair…
  • Announcements
      On-demand appliance repair training videos for Professional Appliantologist members Over 30 hours (and growing!) of original, high quality appliance training webinars developed and given by yours truly are at your fingertips, on topics you won't find anywhere else. Fill in those knowledge gaps, strengthen those areas of uncertainty, and boost your skills. Watch on mobile or desktop at your convenience whenever, wherever.  Ultra Short Primer on Basic Electricity, Circuits, Ohm's Law, and Schematic Reading (Length: 1:04:48) Basic Refrigerator Troubleshooting (Length: 1:10:45) Schematic Reading Workshop, 10/2015 (Length 1:19:08) Troubleshooting Strategies for Computer-Controlled Appliances (Length: 48:34) Semiconductors and PN Junctions (Length: 1:04:37) Appliance Temperature Sensing Devices & Technology (Length: 1:27:33) Voltage Measurements, Meters, Ghost Voltages, and Triac-controlled Neutrals (Length: 1:29:32) Troubleshooting with Tech Sheets, Part 1, 4/2016 (Length: 1:09:26) Troubleshooting with Tech Sheets, Part 2, 4/2016 (Length: 1:21:11) Tech Sheet Review, 4/9/2016: Bosch Speed Cooker, Amana Refrigerator, GE Glass Cooktop Range (Length: 1:22:58) Pulse Width Modulated (PWM) Switches used in Samsung Switched Mode Power Supplies (SMPS) (Length: 27:07) PWM Computer Cooling Fan in a Whirlpool Refrigerator (Length: 14:53) Understanding AC Split-phase Household Power Supplies (Length: 52:41) Troubleshooting a Samsung Electric Dryer without Disassembly using Live Tests and the Schematic (Length: 22:47) Troubleshooting a Bosch Dishwasher No-Heat Problem using the Schematic and Live Tests (Length: 15:38) Linear Motors and Linear Compressors (Length: 55:54) Bi-directional PSC Drive Motor Systems in Whirlpool VM Washers (Length: 56:52) Appliance Service Call Structure and Troubleshooting Strategies (Length: 1:00:16) The Ten Step Troubleshooting Tango and Workshop Exercises (Length: 1:35:39) Troubleshooting Ten-Step Tango Advanced Workshop (Length: 1:32:06) Ten-Step Tango Troubleshooting Workshop: Refrigerators (Length: 1:35:57) Whirlpool Duet Washer Schematic Analysis & Whirlpool Dryer Moisture Sensor System (Length: 1:03:04) Neutral Vs. Ground, Inverter Microwave, Digital Communications, Loading Down in DC loads, and more! (Length: 1:14:45) Gas Oven Service Call After a Parts Changing Monkey (Length: 36:04) AFCI and GFCI Circuit Protection Technology (Length: 41:26) Troubleshooting Samsung Refrigerators and more (Length: 1:29:58) 3-way Valves and Dual Evaporator Refrigerators (Length: 1:15:45) Split-Phase Compressors and PTC Start Devices (Length: 1:11:57) Gas Dryer Ignition Systems (Length: 53:50) Refrigerator Sealed System Thermodynamics, Part 1 (Length: 43:07) Refrigerator Sealed System Thermodynamics, Part 2 (Length: 1:09:09) Refrigerator Sealed System Thermodynamics, Part 3 (Length: 1:11:56) Refrigerator Sealed System Thermodynamics, Part 4 (Length: 37:45) Refrigerator Sealed System Thermodynamics, Part 5 (Length: 16:35) To access these webinars and all the other info-goodies here at Appliantology, become a Professional Appliantologist today. If you need cost-effective, time-flexible, state-of-the-art appliance technical training, check out the Master Samurai Tech Academy.
    • Son of Samurai
    8
    45
    7,114
Sub Zero freezer side hot gas loop freon leak
AlboGator
I've run into a few of these over the years from multiple model numbers and would like to share what I've found with the rest of you guys so hopefully you don't have to learn the hard way. Symptom is that the freezer will not get cold and they may tell you about a hiss even. You get there and put your gauges on it and find it's drawing a suction on the process tube. So after pressure testing the system you find there's a leak in the hot gas loop.
Well here's where it turns into a mess. That hole in the gas line is allowing water to get into the sealed system and you'll never get it out. The only solution is a total sealed system replacement and a really good flush out of the remaining lines using either rx11 or some sort of refrigeration system flush to flush both the condenser and the mullion heater lines to get everything out, followed by nitrogen to flush out the flush.
Here's the last one I ran into, somewhat start to finish along with follow up pictures of the evaporator and compressor cut open to reveal the water that gets sucked into the system and what the water will do to the internals of the compressor. Some are just pictures of brazes. Sometimes I'll take a pic of the backside to look at them, sometimes I think they're pretty, and sometimes I'll just document it to look at 10 years from now. Anyway I left the album raw, meaning if I took a pic that wasn't fuzzy I put it in the album. This job took me 5 1/2 hours to finish and I did it in place not removing the refrigerator from the cabinet.
http://imgur.com/a/2xJaZ
  • Like 3
10 Comments
for that complex of a repair how much labor did you bill the customer?
Share this comment
Link to comment
That was some impressive work. I smiled when I got to the picture of the frosted evaporator. I really loved the detail of the piston and cylinder. I sometimes leave a set of gauges on these jobs and go back the next day to check the pressures; if they change at all, I wait a few days and return to change the dryer again.
My worst experience was encountering this very repair, about 15 years ago. I had to remove the cabinet to install the heat exchanger from the top, and the factory sheet called for an electric tray heater wired to the evap. fan, and mounted under the condensate tray.
Good work!
Share this comment
Link to comment
As did I, Thank you.
Share this comment
Link to comment
Another battle won in the war of renegade appliances Wobiii Konobe
Share this comment
Link to comment
Holly sheeeeet...that is a right respectable piece of work.  I have to find me a good sealed system guy to refer any work like this to.  I am not equipped for that.
Share this comment
Link to comment
APPLIANCE DEAN
That is definitely a boss repair. BRAVO. great pictures too.
Share this comment
Link to comment
Nice job here!
Now, if a Frigidaire Gallery all refrigerator had a leak in the hot gas loop - are those known to have the same problem? I'm replacing the loop and the compressor already but really don't want to do the evaporator if I don't have to.
Share this comment
Link to comment
I've only done one frigidaire that had a leak and no, it wasn't contaminated like this one was. I've also done a few of the french door whirlpools that get the leak in the copper line that runs in through the water pan and they were fine just changing the line and the filter.
Share this comment
Link to comment
wow Albo Gator you are impressive when it comes to reading your experiences with refrigeration systems. I am still learning new stuff with just the regular appliance repair scenario's. I went to school and  I did take up a refrigeration class and did pass and receive my refrigeration certification license but the stuff still scares me a little and keeps me from getting and doing refrigeration work on refrigerators. I have not been in the scene of domestic refrigeration system repair for the past 5 years since I graduated appliance repair school here where I live. I can only turn down so many fridge jobs before it affects one of the management companies I do work for you know.  The refrigerators are usually the basic apartment ones that when They have a loss of refrigerant It usually is not economically in their favor to repair and recharge. so They opt to buy new.Some are bosch and GE side by sides but I haven't run into any refrigeration loss issues with those models but i'm sure its a matter of time.  Well thanks for your help and time with your repair situations and knowledge on this site. I hope to be as good as that some day But i'm shooting 53 years of age at this point and I don't see it coming anytime soon.
Share this comment
Link to comment
Quote
Hang in there and don't get too set in your ways, remember "whether you think you can or think you can't you are right" either way. Even with the experience I have I'm realized that I should start to re-examine some of the things I do every day. I don't always know the best way, but know the way that has worked for me and realize that someone else may know a better way, different way, quicker way or more accurate way. I may be that person, very well may not! We never stop learning. And I appreciate your kind words.
Share this comment
Link to comment
