Learn how to troubleshoot using schematics like a real tech…
Sign in to follow this
Followers 0
    2
    7
    656
Introducing BoardFruit, Inc!
Followers 0
BoardFruit
We are hardware engineers with over ten years of specialization in appliance controls.  We started out repairing control boards - mostly for ovens, refrigerators, and a few microwaves.
Anybody who works on appliances knows well that the electronics do not last long.  In fact, it appears they work just long enough to outlast manufacturer warranties and parts supply lines.  When they do fail, replacement control boards are generally pretty hard to find, and expensive when available.
You can get hard-to-source control boards repaired by a number of different operations around the country, but the success rate isn't the most reliable.  Often, the homeowner's equipment can have a number of different parts failures, and the control board is just the tip of the iceberg.  Even worse, nobody fixes touchpads.  If a touchpad fails, and no replacements can be found, the whole appliance has to go to the landfill!!
We are putting an end to this.  Imagine: one control board package that can go into nearly any appliance and comes with its own remote touchpad.  Anytime we think there might be a control failure or touchpad failure (think F1 error codes), we can just pop one of those babies in and find out real quick whether we've solved the appliance failure.  Even better! What if that control board had on-board diagnostics that could tell you what else might be the problem in the appliance?
Sounds too good to be true if you ask me.  Unfortunately, it is....for now.  But we are working on this!  We actually do have our first product out right now.  It's nowhere near as sophisticated as what I've just described, but it's still pretty cool, and it's keeping expensive Dacor ovens out of the landfill.
We've made a slick little gadget that installs on the backside of a failed Dacor oven panel and connects to the OEM control board in place of the OEM touchpad.  This little gadget also comes with a 7" touchscreen tablet booted with our custom software - a wireless, digital touchpad that restores full control of the Dacor oven to the homeowner.  Check out the next blog post for more details!!
This is our introduction to the Appliantology community.  We hope to work together with anybody interested.  We want your input, feedback, insults, and compliments.  Oh, and hopefully you like our products enough to buy them, as well :P
Cheers!
Followers 0
