Learn how to be your own tech line...
  • Announcements
      On-demand appliance repair training videos for Professional Appliantologist members Over 30 hours (and growing!) of original, high quality appliance training webinars developed and given by yours truly are at your fingertips, on topics you won't find anywhere else. Fill in those knowledge gaps, strengthen those areas of uncertainty, and boost your skills. Watch on mobile or desktop at your convenience whenever, wherever.  Ultra Short Primer on Basic Electricity, Circuits, Ohm's Law, and Schematic Reading (Length: 1:04:48) Basic Refrigerator Troubleshooting (Length: 1:10:45) Schematic Reading Workshop, 10/2015 (Length 1:19:08) Troubleshooting Strategies for Computer-Controlled Appliances (Length: 48:34) Semiconductors and PN Junctions (Length: 1:04:37) Appliance Temperature Sensing Devices & Technology (Length: 1:27:33) Voltage Measurements, Meters, Ghost Voltages, and Triac-controlled Neutrals (Length: 1:29:32) Troubleshooting with Tech Sheets, Part 1, 4/2016 (Length: 1:09:26) Troubleshooting with Tech Sheets, Part 2, 4/2016 (Length: 1:21:11) Tech Sheet Review, 4/9/2016: Bosch Speed Cooker, Amana Refrigerator, GE Glass Cooktop Range (Length: 1:22:58) Pulse Width Modulated (PWM) Switches used in Samsung Switched Mode Power Supplies (SMPS) (Length: 27:07) PWM Computer Cooling Fan in a Whirlpool Refrigerator (Length: 14:53) Understanding AC Split-phase Household Power Supplies (Length: 52:41) Troubleshooting a Samsung Electric Dryer without Disassembly using Live Tests and the Schematic (Length: 22:47) Troubleshooting a Bosch Dishwasher No-Heat Problem using the Schematic and Live Tests (Length: 15:38) Linear Motors and Linear Compressors (Length: 55:54) Bi-directional PSC Drive Motor Systems in Whirlpool VM Washers (Length: 56:52) Appliance Service Call Structure and Troubleshooting Strategies (Length: 1:00:16) The Ten Step Troubleshooting Tango and Workshop Exercises (Length: 1:35:39) Troubleshooting Ten-Step Tango Advanced Workshop (Length: 1:32:06) Ten-Step Tango Troubleshooting Workshop: Refrigerators (Length: 1:35:57) Whirlpool Duet Washer Schematic Analysis & Whirlpool Dryer Moisture Sensor System (Length: 1:03:04) Neutral Vs. Ground, Inverter Microwave, Digital Communications, Loading Down in DC loads, and more! (Length: 1:14:45) Gas Oven Service Call After a Parts Changing Monkey (Length: 36:04) AFCI and GFCI Circuit Protection Technology (Length: 41:26) Troubleshooting Samsung Refrigerators and more (Length: 1:29:58) 3-way Valves and Dual Evaporator Refrigerators (Length: 1:15:45) Split-Phase Compressors and PTC Start Devices (Length: 1:11:57) Gas Dryer Ignition Systems (Length: 53:50) Refrigerator Sealed System Thermodynamics, Part 1 (Length: 43:07) Refrigerator Sealed System Thermodynamics, Part 2 (Length: 1:09:09) Refrigerator Sealed System Thermodynamics, Part 3 (Length: 1:11:56) Refrigerator Sealed System Thermodynamics, Part 4 (Length: 37:45) Refrigerator Sealed System Thermodynamics, Part 5 (Length: 16:35) To access these webinars and all the other info-goodies here at Appliantology, become a Professional Appliantologist today. If you need cost-effective, time-flexible, state-of-the-art appliance technical training, check out the Master Samurai Tech Academy.
    • Son of Samurai
    7
    41
    6,799
Faking a fan feedback signal
AlboGator
I had a Samsung fdbm refrigerator where the week before christmas I got a no cool complaint. Checking the part, it had to be shipped in. It arrived that Friday, and of course it was the wrong evap cover. I devised a plan, but thankfully didn't have to use it. In the end I was able to swap the fan motors and use the existing evap cover but just for fun I garaged a proof of concept using a simple voltage divider circuit.
What it does is take the I put to the fan, and divides it into a lower voltage to tap into and feed back. The output voltage is dependent on the input voltage. It took a bit of playing with to get it right, but it would have worked.
This was the only time I've seen this happen btw.
8 Comments
Pretty awesome hack and a nice demo of tricking out the microprocessor looking for a missing RPM signal. Thanks for posting this!
Share this comment
Link to comment
AlboGator
Experiments are fun. Was wondering "This thing on", lol.
Share this comment
Link to comment
Took me a while to get settled back in after San Diego.
I think some techs may not realize that this is much more than just a hack--  which is its own reward-- but it's a practical demonstration of how understanding the fundamentals of the technology we're working with on modern appliances can empower us as professional technicians to "think outside the flowchart."
Besides all that, it has an intense cool factor!
Share this comment
Link to comment
AlboGator
Hacking is fun, and it's easier with the modern stuff. There is a world of possibilities with the technology they're using now vs a simple open/closed switch before all of the cool stuff came out. I've got a chip that will run an inverter for a compressor as well. I like making tools to hack appliances brains.
Share this comment
Link to comment
Joe B, Stoughton Appliance Repair
Nice work Walt!
I didn't get a full view of your schematic and couldn't figure out what you did to calculate resistor sizes.
Can you elaborate?
Thanks!
Share this comment
Link to comment
Thanks for the diagram Walt,
I will have to google this, because I'm confused on on what R2 is doing.  It seems to my mind that a properly sized R1 alone would provide a Vdrop so that +out would give a proportional signal to +in.
It's a good practical exercise, I'll have to investigate.
Thanks again.
Share this comment
Link to comment
AlboGator
Try it out, see what happens. Sounds like a good project if you can make it work that way.
Share this comment
Link to comment
