  1. Today
  2. You should ba able to use this: This service Bulletin:
  3. Kitchenaid refrigerator Model #KRFC300ESS01 not cooling. Put it in diagnostic mode and all fans & thermistors appear to be working. I'm pretty sure the start relay is also working, as it does appear that the compressor kicks on, but it's still not cooling. Is it possible that the compressor kicks on, but the issue is still with the start relay or associated capacitor? The only other thing I can think of is a refrigerant leak, and if that's the case it's not worth fixing, so thought I'd see if anyone here has any ideas. Here is a video of the compressor that starts just as the refrigerator is plugged in. There is a click about 30 seconds in, but the compressor does not come on. FF to the ~1:50 mark and you'll hear the compressor finally kick in about 2 min after plug-in. As far as I can tell, it's not cycling on and off (I'm not hearing tell-tale clicks), but I really can't be sure. Does this sound like normal operation, or am I missing something? Does this sound like a compressor low on refrigerant? It appears that it *may* be cooling the freezer compartment from room temp (~72F) to about 67F, but can't cool beyond that. TIA
  4. TurtleRock
    Hisense Refrigerator
    thanks
  5. Manufacturer: Samsung Type of Appliance: Refrigerator Model Number: RF28T5001SG Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for service manual for above refrigerator. Thank you in advance
  6. Captain Dunsel
    Ge cook top tech sheet
    Uploading mini manual and waiting on approval:
  7. Manufacturer: GE Type of Appliance: Cooktop Model Number: Jgp633set3ss Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Yoooo I been trying to search for a tech sheet on this ge cooktop, searched appliantology a handful of times and couldn't find it. Anyways if you can find it that'd be great! Thank you! Jgp633set3ss
  8. Looking for advice on replacing oven igniter in Bosch 500 series oven. Online videos show splicing the wires and connecting with ceramic wire nuts. Doesn't look there is any access to the oven igniter without disassembling quite a bit of the oven (gas lines, valves, convection fan, thermostat, etc...). Any suggestions or advice appreciated. The connector for the broiler igniter is in the open and accessible, don't see the oven igniter connector so I assume it is behind the back panel. Any advice or suggestions appreciated. Thanks
  9. Son of Samurai
    Thermador Service Manual Request
    Uses this manual:
  10. Uses this manual:
  11. Thanks, Cap!
  12. Thanks, Cap!
  13. Son of Samurai
    Apologies for the tardiness -- thanks, Captain!
  14. Whirlpool CAE2745FQ2 Washer Tech Manual View File Pub Tech Manual -W11681277 - Rev B Submitter Captain Dunsel Submitted 06/13/2025 Category Appliance Repair Manual Pot Luck Supper
  15. GE PP912KM2CC Cooktop Mini Manual View File Pub 31-14525 Submitter Captain Dunsel Submitted 06/12/2025 Category Appliance Repair Manual Pot Luck Supper
  16. Hisense HRT180N6ABD HRT180N6AWD HRT180N6AVD Refrigerator Service Manual View File Pub No number Models: BCD-516WY_HC1(H) Submitter Captain Dunsel Submitted 06/11/2025 Category Appliance Repair Manual Pot Luck Supper
  17. Captain Dunsel
    I don't.
  18. TurtleRock
    Captain thanks for upload. I didn't notice in manual about a force defrost. Any thoughts on how to accomplish this task?
  19. @WestTn May have some similarities to Parts of this manual: @WestTn Looks like you can also use this tech sheet as it looks the same as the one I am uploading!
  20. DStenoien
    Tech sheet needed
    Thank you.
  21. Captain Dunsel
    Tech sheet needed
    Uses this service tech sheet: This wiring diagram:
  22. Version 1.0.0
    2 downloads
  23. Uploading tech sheet and waiting on approval:
  24. Manufacturer: KitchenAid Type of Appliance: Refrigerator Model Number: KSRS25CSMK02 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need tech manual.
  25. Uses the same as this model: This service manual:
  26. Pretty sure it a normal R.H. Thread - I do think it maybe metric but don't know the size, (generally nuts that are used in applications such as this are really thin - like around only 1/16" to 1/8" thick).
