  1. Today
  2. vee8power
    tech sheet needed for dryer
    This one should work:
  3. Manufacturer: kenmore Type of Appliance: dryer Model Number: 11061402311 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes tech sheet needed
  4. Manufacturer: GE Type of Appliance: Washing Machine Model Number: WHSE5240d1ww Have you validated the model number at an online parts site like Repair Clinic? (yes or no): y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): y Hello, have another older Washer to give me hell I hope the outcome is different for me!!! Hope you have this manual
  5. Manufacturer: GE Type of Appliance: Laundry center Model Number: GUD27GSPM1DG Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Customer complaint. selector control problem
  6. rokosz
    Maytag Washer LAT9614AAE
    so yes my "test" run found two perforations in the outer tub. Looks like that tub might be obsolete now for over 10 years. I know I got a lot of good years out of it. And I wouldn't want to hold on to it so badly if modern units could hold a candle to the reliability of yesteryear. So, I'm still, ahem, fishing. Looking for ideas on spray epoxy. Both pin holes are on the "deep" end of the tub near the pump drain. surrounding areas are strong. Epoxy is water proof, the tub is not under pressure - I thought if I were to coat the entire inside surface... or at least the bottom of the tub to the height of the retaining bolts. I saw a few threads here re: epoxy --, but no clear Reccos.. What do you think? thanks for looking. I've also got some Seen-On-TV Flexseal. But I'm not too high on that. I used it on a vinyl collapsible rain barrel and its peeling away, wrapped it around a down spout that got sliced by a snow blower (never worked).
  7. Yesterday
  8. Soft water may be an issue if it only leaks during the clean cycle. I had this issue with my brand-new washing machine. Finally, I called the serviceman. He said that with a water softener, there are too many suds, and the suds spill over into the vent, causing the leak. He said only to use a ½ tablet of the washer cleaner (Affresh or other brands).
  9. Uploading parts list and waiting on approval:
  10. rokosz
    never mind. Not following the instructions as closely as I should've: installed 2 nut clamps. One on top of the stem and the old one inside the inner tub. Of course for ~25 yo outer tub, my test run shows a 3mm rust perforation in the base of the outer tub near the drain. I must've completed the perf. when I was cleaning.
  11. Manufacturer: Fulgor Milano Type of Appliance: Oven Model Number: F6PDP30S1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Does anyone know how to get manuals or parts for these things? I called there support line, and was asked to leave a message. I seriously doubt that I will ever hear back from them.
  12. samedayapprepair
    Service manual for frigidaire micro oven combo
    Hi @Captain Dunsel, can you please forward me part list? thks
  13. This workhorse has been problem free for somewhere between 22 and 28 years (It was here when I moved in 22 years ago). Things wear out. leaking started, and got more consistent and voluminous. id'd drips from the center spindle. Elected to do stem and bearing replacement. got the bearing done quickly but had to wait a bit for the stem kit (no longer available from Whirl/Mayt -- never happy buying Chinese knock-offs) It showed up & I continued the replacement/installation up through tightening the set screw on the stem. now replace the inner tub, then the washer clamp/cap and finally the nut/screw clamp. But the nut screw clamp can't find purchase of the threads on the stem. You can see in the att. pics even before the cap is placed there isn't alot of TPI visible. Its like somewhere in there I lost a 1/2 inch of height or maybe its time to call a Chinese Knock-off Alert. I've been using two different vids as my mentors. They haven't been perfect but between the two of them it should be a predictable repair. I'm following consistently and disassembled and started again from the stem bellows with the same result Can anyone offer a little guidance on this or tip? thanks. or https://youtu.be/thX1aqNXsYk?t=858
  14. Manufacturer: Kenmore/LG Type of Appliance: Washer Model Number: 796.41362.910 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Y TY! ref14439
  15. Samurai Appliance Repair Man
    Appliantology Live Dojo, Saturday, 4/27/2024 @10 AM ET
    until
    This one is a Whirlpool WRT311FZDW01 refrigerator that uses the tech sheet posted below. Questions we'll be going over: You've got a no-defrost complaint. What's your LOI? What is the spec you'll use to determine whether or not the defrost heater is actually heating properly? Where will you place your probes to measure the voltage supply to the heater? If volts are in spec, what's your next test to confirm proper heater operation? Entering service mode on this model is wonky and hit or miss (at least in my experience). Suppose you can't enter service mode no matter what you do. What's another good way to test the defrost heater?
  16. You can use this manual:
  17. Manufacturer: KitchenAid Type of Appliance: Refrigerator Model Number: KSRG25FKSS04 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES Hi to everyone! I have a KitchenAid KSRG25FKSS04 refrigerator ice-maker not working. Do you have any service bulletin or service manual for this model?
  18. Samurai Appliance Repair Man
    until
    Another tech sheet for us to practice on. This one is another Frigidaire but a refrigerator this time. Model number LGHB2867PF7A. Tech sheet is below. Here are the study questions: What kind of power supply does the augur motor require? When the board supplies one side of the power supply to the augur motor, where does that wire travel before it makes it to the motor itself? What's a reasonable test to do to confirm that the augur motor is capable of running with a proper power supply? If you find the augur motor is not getting voltage, where is your next stop looking for the missing voltage? If the cube crush solenoid is getting voltage, does that mean that the auger motor should be getting voltage, too? Why or why not?
  19. Samsung DVE45N6300V/AC Dryer Service Manual View File PROJECT : DV6300N Model Name : DVE45N6300V/AC Submitter Captain Dunsel Submitted 04/24/2024 Category Appliance Repair Manual Pot Luck Supper
  20. Samurai Appliance Repair Man
    until
    I think you'll nail it. This should be easy stuff for experienced techs. We've had requests from newer techs to practice reading tech sheets and picking out details. @Son of Samurai will be posting a few other tech sheets with study questions. We'll have a troubleshooting party!
  21. Koi Guy
    until
    I'll be there with answers. Maybe not correct answers, but answers nonetheless.
  22. Shaphan Hawks
    Need tech Sheet/manual
    I'm familiar with these Daewoo build refrigerators. Let me know if you need help.
  23. Shaphan Hawks
    I found it: https://www.dropbox.com/scl/fi/xvr69xly3ckrsn4b20sbp/Service_Manual_Crosley_TMF21_CRD2123NB-CRD2123ND-CRD2123NW_010320.pdf?rlkey=eeghfc12szbm26x0munnuu3p8&dl=0
  24. May have some similarities to this manual: Uses this mini manual:
