Upcoming Events
30 March 2024 02:00 PM Until 03:00 PM
0All Appliantology tech members are invited to join in this workshop on all things Appliantological: bidness, customers, tools, troubleshooting, flavorite brewski, whatever. Webcams and microphones are open and live!
This workshop is also a great time for any students at Master Samurai Tech to bring any and all questions about the coursework. We're happy to walk through any concepts you're having trouble with. Think of it like office hours with your teachers.
If you have a specific appliance problem you'd like us to talk about, post it here! We need a problem statement and a PDF of the tech sheet or schematic so we can all see it on screen share. If you have a PDF that isn't already in the File library here at Appliantology, send it to us by attaching it to the contact form.
Who: This workshop is only available to tech members at Appliantology.
Where: Online via Zoom
Click here to go to the forum topic with the registration link. If you're interested, register now. Arrive a couple minutes early to make sure your connection is working. Set a reminder for yourself for this workshop so you don’t miss it. And check out past workshops here: https://appliantology.org/announcement/33-webinar-recordings-index-page/
- Past hour
Kenmore Dryer 110.75962401—Replace Door Switch?
Budget Appliance Repair replied to MarkH's topic in DIY Appliance Repair Help
Yes, you need to replace the door switch -
GE Model: JGB281DER4WW Part # WB28K10782 snapped surface burner orifice holder
Budget Appliance Repair replied to EliasX's topic in DIY Appliance Repair Help
My bet is that you tried to raise the top without removing the three torq head screws around each of the burners - this will crimp and break the aluminum gas lines to the burners, (usually the front because they are short and don't have the flex that the rear burners have). Sears shows the WB28K10782 in stock but they are really famous for saying parts are in stock and if you call them they will say the same thing the website say, "Ya, we have it in stock". You will order then two weeks later you might get a notice it's no longer available or maybe even longer if you don't follow up on it. As far as a custom line, NO - the orifice holder end is special. The only chance to fix the original one is if it's not broken/bent to badly and cut it with a tubing cutter as close to both sides of the crimp/break as you can and install a brass compression tubing connector fitting. Here's a picture of what yours looks like: Here's one I found on Ebay when looking for yours - it looks pretty close and you should be able to remove the orifice and replace with the orifice from yours, (sometimes that might be the only difference - the drill size of the orifice). New Genuine OEM GE Oven Range Surface Burner Tube and Orifice WB28K10190 on Ebay for $21 to $25 or this one - there's a used one on Ebay for $5 + $10 shipping. Part# WB28K10736 - Today
I have a bosch dishwasher with an e24 error code
Advance1 replied to BRUNOJX's topic in DIY Appliance Repair Help
Another item to check is the heat pump. The control board runs the heat pump before the drain pump. The heat pump is used to check to see if there is water in the tub. I had a dishwasher getting E24 and there were no issues with it draining but the control board thought there was a draining issue based on the heat pump. I would be curious if that noise is actually the heat pump. Hard to tell in the video. Clint -
MarkH started following Kenmore Dryer 110.75962401—Replace Door Switch?
When I opened the dryer to add a load of laundry, the light didn't come on. Same thing happened a couple of months back and the bulb was loose. Checked the bulb again today but filament looks okay. Then I noticed that the switch flapper had no resistance when pressed. Went on to dry the load and discovered that the dryer didn't stop when the door was opened during the intermittent beep air dry cycle. Just seeking confirmation that this is a door switch issue or what else might need to be checked. Thanks in advance for any help.
Dfish81 joined the community
MatthewF replied to BRUNOJX's topic in DIY Appliance Repair Help
E24 is usually indicating slow/no drain in the unit. In my experience it's more often than not something clogged in the system rather than a bad pump. Few things to check (usually before replacing the pump). First, take the hose off the connection under the sink and stick a screwdriver down there to see if anything is stuck. Second, vacuum out the system. Start with the hose, then the sump. Then fill it a bit and see if it drains. If not, I vacuum it out again, take the silver kick panel off and remove the pump to see if anything is stuck in there. You can also disconnect the drain hose from the sump and vacuum that out too. If you have the pump off, make sure it's spinning properly too. I don't remember the last time I actually had to change a pump though. It's almost always a clog. In theory you could have it cleared out and draining in 15 minutes without pulling the unit out of the cabinet! All that said, that noise sounds like somethings up with the pump. Did you make sure the pump is for sure the right model? I know there are a bunch that fit but have slightly different voltages so could possibly act weird. The pump part number for that unit should be 00611332. -
PP11 joined the community
tuchu480 joined the community
12345 joined the community
kobr joined the community
jmlavoie joined the community
- Yesterday
Phil Melli joined the community
Need service manual for Miele washer
Eugeneapp posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Miele Type of Appliance: Washer Model Number: WXF660WCS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): no Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hello, need a service manual for Miele washer, model #WXF660WCS. -
KitchenAid KICU569X Induction Cooktop Replacement
BPs YetAnother Project replied to BPs YetAnother Project's topic in DIY Appliance Repair Help
Mistake above, the opening is 20" by 33 1/16". -
loki2112 joined the community
GE Advantium PSB11001NSS Microwave made a pop noise an no longer heats.
Grumpy_Mike replied to Grumpy_Mike's topic in DIY Appliance Repair Help
Just realized I have an extra digit in the pn. PSB1001NSS 01 is correct. -
Samsung undercounter wine chiller service manual request
Son of Samurai replied to Dkauai's topic in Appliance Service Manual Requests Forum
Here you go: -
New Appliance Service Manual added: Samsung RW51TS338SR/AA Wine Cooler Service Manual
Samsung RW51TS338SR/AA Wine Cooler Service Manual View File Model Name: RW51TS338 Submitter Son of Samurai Submitted 03/18/2024 Category Appliance Repair Manual Pot Luck Supper -
RT16A6105WW Samsung Refrigerator service manual or tech sheet needed
Son of Samurai replied to Centre St-Exupery's topic in Appliance Service Manual Requests Forum
Here you go: -
New Appliance Service Manual added: Samsung RT16A6105WW Refrigerator Service Manual
Samsung RT16A6105WW Refrigerator Service Manual View File MODEL NAME: RT44* / RT48A* / RT16A MODEL CODE: RT48A6684** RT48A683F** RT48A6004** RT16A6195** RT48A6H87** Submitter Son of Samurai Submitted 03/18/2024 Category Appliance Repair Manual Pot Luck Supper -
EliasX posted a topic in DIY Appliance Repair Help
Hello, Long story short, I was trying to impress the wife by deep cleaning our gas stove and broke a pipe that runs from the stove knob to the surface burner. I believe it's called an "orifice holder". We have an older store and I have not been able to locate the part anywhere. This part is discontinued and out of stock at all the parts supply sites I looked at. I know nothing about stoves, my question is, is it possible to make a custom pipe to replace the broken one? I would hate to have to buy a new stove because I can't find a $25 part. -Thank you in advance, -Elias -
Dkauai posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Samsung Type of Appliance: Wine chiller Model Number: RW51TS338SR/AA Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Scheduling this call for tomorrow. Is there a service manual available? This model is just outside of warranty. Any help would be appreciated! Thanks guys! DK -
EliasX joined the community
Manufacturer: samsung Type of Appliance: refrigerator Model Number: RT16A6105WW Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES I need the service manual or the tech sheet for this refrigerator. thanks -
Service Manuel Request
Captain Dunsel replied to Rich Armstrong's topic in Appliance Service Manual Requests Forum
You can use this service manual and that same tech sheet:- 1 reply
- 2
Manufacturer: Whirlpool Type of Appliance: Dryer Model Number: WED5100HW0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Low Heat
Kenmore Elite Front Load Manual Request
Captain Dunsel replied to Scottdottcom's topic in Appliance Service Manual Requests Forum
You should be able to use this one:- 1 reply
- 2
Scottdottcom posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kenmore (LG) Type of Appliance: Front Load washer Model Number: 79641073311 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Unable to locate this manual. LE error and this model does not have the speed sensor on the stator. Only one connector instead of the two connectors i have become familiar with over the years. Sensor not shown in the breakdown illustration but listed at the bottom of the parts list on SPD. -
Samsung NE63A6511S* Electric Range Service Manual
MatthewF commented on Samurai Appliance Repair Man's file in Appliance Repair Manual Pot Luck Supper
Samsung Washer Service Manual Needed
Son of Samurai replied to nwjudge's topic in Appliance Service Manual Requests Forum
Here you go:- 1 reply
- 2
New Appliance Service Manual added: Samsung WA50B5100AV/US Washer Service Manual and Parts List
Samsung WA50B5100AV/US Washer Service Manual and Parts List View File Basic Model: WA51A5505AW/US (WA5000A PROJECT) Model Code: WA50B5100A* WA49B5105A* (WA5100B PROJECT) Submitter Son of Samurai Submitted 03/18/2024 Category Appliance Repair Manual Pot Luck Supper -
Blog Entries
6 comments
8 comments
12 comments
Topics
