  2. Water pressure was really high! Filter only 4mos old. Inlet valve showed resistance but no continuity. Power to inlet valve confused me. It showed 2v with door open, 3v with door closed, and dropped to 0v when I press the water dispense paddle (while pressing door switch). But I could hear a click from the valve area like it was getting power! 🤔 Recommended the valve first. wondering if anybody else has other ideas or experience with this model?
  3. BaineB254
    GE GTW335ASN2WW won’t finish cycle
    Update! After removing the metal piece from the outer tub and replacing the drain pump it starts working 🥳
  4. Today
  5. Captain Dunsel
    Tech Info.
    Uploading mini manual and waiting on approval:
  6. Uses the same tech sheet as this model:
  7. Captain Dunsel
    790.8883110 Kenmore microwave tech sheet needed
    Uploading wiring diagram, parts list and waiting on approval:
  8. Manufacturer: Kenmore Type of Appliance: Washing Machine Model Number: 110.21102011 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES Service manual please 110.21102011
  9. Manufacturer: Kenmore Type of Appliance: Microwave Model Number: 790.48883110 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Found a similar model number manual already, but it's not close enough. Have to go back to this and the info would be helpful. Thanks, Charlie
  10. vee8power
    Whirlpool top loader unknown part.
    They hold the suspension in place during shipping. Throw the pins and cups in the garbage.
  11. apache23
    Both of the cups were attached, with pins in them, but came off when I installed suspension pads. What are the pins for? Thanks for your response!
  12. evaappliance
    Maytag Washer LAT9614AAE
    Have done many with epoxy, just give it plenty of time to dry thoroughly
  13. vee8power
    tech sheet needed for dryer
    This one should work:
  14. Manufacturer: kenmore Type of Appliance: dryer Model Number: 11061402311 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes tech sheet needed
  15. Manufacturer: GE Type of Appliance: Washing Machine Model Number: WHSE5240d1ww Have you validated the model number at an online parts site like Repair Clinic? (yes or no): y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): y Hello, have another older Washer to give me hell I hope the outcome is different for me!!! Hope you have this manual
  16. Manufacturer: GE Type of Appliance: Laundry center Model Number: GUD27GSPM1DG Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Customer complaint. selector control problem
  17. rokosz
    so yes my "test" run found two perforations in the outer tub. Looks like that tub might be obsolete now for over 10 years. I know I got a lot of good years out of it. And I wouldn't want to hold on to it so badly if modern units could hold a candle to the reliability of yesteryear. So, I'm still, ahem, fishing. Looking for ideas on spray epoxy. Both pin holes are on the "deep" end of the tub near the pump drain. surrounding areas are strong. Epoxy is water proof, the tub is not under pressure - I thought if I were to coat the entire inside surface... or at least the bottom of the tub to the height of the retaining bolts. I saw a few threads here re: epoxy --, but no clear Reccos.. What do you think? thanks for looking. I've also got some Seen-On-TV Flexseal. But I'm not too high on that. I used it on a vinyl collapsible rain barrel and its peeling away, wrapped it around a down spout that got sliced by a snow blower (never worked).
  18. Yesterday
  19. Soft water may be an issue if it only leaks during the clean cycle. I had this issue with my brand-new washing machine. Finally, I called the serviceman. He said that with a water softener, there are too many suds, and the suds spill over into the vent, causing the leak. He said only to use a ½ tablet of the washer cleaner (Affresh or other brands).
  20. Uploading parts list and waiting on approval:
  21. rokosz
    never mind. Not following the instructions as closely as I should've: installed 2 nut clamps. One on top of the stem and the old one inside the inner tub. Of course for ~25 yo outer tub, my test run shows a 3mm rust perforation in the base of the outer tub near the drain. I must've completed the perf. when I was cleaning.
  22. Manufacturer: Fulgor Milano Type of Appliance: Oven Model Number: F6PDP30S1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Does anyone know how to get manuals or parts for these things? I called there support line, and was asked to leave a message. I seriously doubt that I will ever hear back from them.
  23. samedayapprepair
    Service manual for frigidaire micro oven combo
    Hi @Captain Dunsel, can you please forward me part list? thks
  24. This workhorse has been problem free for somewhere between 22 and 28 years (It was here when I moved in 22 years ago). Things wear out. leaking started, and got more consistent and voluminous. id'd drips from the center spindle. Elected to do stem and bearing replacement. got the bearing done quickly but had to wait a bit for the stem kit (no longer available from Whirl/Mayt -- never happy buying Chinese knock-offs) It showed up & I continued the replacement/installation up through tightening the set screw on the stem. now replace the inner tub, then the washer clamp/cap and finally the nut/screw clamp. But the nut screw clamp can't find purchase of the threads on the stem. You can see in the att. pics even before the cap is placed there isn't alot of TPI visible. Its like somewhere in there I lost a 1/2 inch of height or maybe its time to call a Chinese Knock-off Alert. I've been using two different vids as my mentors. They haven't been perfect but between the two of them it should be a predictable repair. I'm following consistently and disassembled and started again from the stem bellows with the same result Can anyone offer a little guidance on this or tip? thanks. or https://youtu.be/thX1aqNXsYk?t=858
  25. Manufacturer: Kenmore/LG Type of Appliance: Washer Model Number: 796.41362.910 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Y TY! ref14439
