  2. Westendappliance
    Maytag mf12269vew5
    You guys are amazing. That should be good.
  3. Today
  4. Son of Samurai
    Maytag mf12269vew5
    @Adirondack Bob's got it! Assuming that's the right number, this tech sheet applies:
  5. Adirondack Bob
    Maytag mf12269vew5
    Try this- MFI2269VEW5
  6. Westendappliance
    Maytag mf12269vew5
    I'll see if I can get them to grab me a pic of it because they said thats what they keep saying it is.
  7. Thanks, missed this one. Saw the one for the *6300 Looks like you get the error codes via the Smart Install Mode on this one.
  8. MrApplianceMatt
    LG Washer WT4801CW Squeaky Noise
    Good stuff! Happy to help!
  9. Son of Samurai
    Fast Track Needed For WF45K6200AW/A2
    Unfortunately, this is the only fast track that Samsung's got for us, and I assume this is what you were already looking at.
  10. Samurai Appliance Repair Man
    Samurai's Big Three Troubleshooting Secrets
    The three step process is a distillation of years spent fermenting on this stuff. Think of it as distilled beer. Is that a thing?
  11. rebsimoneaux
    That's exactly what it was. Changed it out today and seems to be running smooth. Thanks!
  12. Yesterday
  13. Samtech
    Where does the Beer fit in your 3 secret steps troubleshooting process? It looks like you're preparing for a five person service call. 🍺
  14. MrApplianceMatt
    Troubleshoot Error code F6 E2
    Have you accessed the mini manual inside the front of the machine? There should be a legend for the diagnostic LED on the control board.
  15. Hello. Sears does not show any manuals for this model that I can search with. Ice maker is acting up. Thanks. Phil
  16. Found one for the *6300AW but not this. Figure there would not be much difference but I can not get it into diagnostics with what is on that Fast Track. Hoping it is a different key dance or I am in heap big trouble. Got the manual but it basically stinks.
  17. How to troubleshoot the Electronic Control Board and the User Interface on a Maytag Bravos XL washer Model MVWB835DW1?
  18. Madera
    Madera
  19. Son of Samurai
    Maytag mf12269vew5
    Are you sure that's the correct model number? Doesn't pull up as valid for me at either Repair Clinic or Service Matters.
  20. Bintiwangu
    Repairing Samsung Fridges, Simplicity to Supremacy Pt 1
    Encouraging to read this. Thank you Durham!
  21. Westendappliance
    Maytag mf12269vew5
    Just need a manual or tech sheet for this fridge. Put a new board in but can't get it to program
  22. Last week
  23. Samurai Appliance Repair Man
    I hear that a lot-- poor guy! What's funny is that neither me or Mrs. Samurai see it.
  24. Rhubarb Tau
    Samsung Fridge 28HDEDTSR FD Mode
    Yep, rD should run a forced defrost on the Ref. only. Yep, it'll ding constantly while in forced defrost. It will time out on its own, after 30-45 minutes If your Ref. evaporator is frosting up constantly , forced defrost may buy you some time, but won't solve the underlying problem. Either call a professional , or carefully remove the evaporator cover after thoroughly defrosting, check and/or replace the Defrost Sensor (the one clipped to the evaporator tubing with a plastic clip), and check whether the defrost drain is frozen or plugged
  25. Terry.
    GE Dryer Timer repeated failure
    I have an electric GE dryer that takes this same timer. It’s 5 yrs. old and Replaced this timer twice and it just won’t turn even with Pliers now....any suggestions??? Sad girl :(. O
  26. I have had two units work fine for 3 summer months, then when I restarted them in the Spring the compressor would not turn on. Cleaning the sensor did nothing The unit was replaced by Electrolux but now the replacement unit is malfunctioning as well. There is something like a slow refrigerant leak in these units, and I would ALWAYS try to get a retund and buy a different brand.
  27. Budget Appliance Repair
    Your Son-of-Samurai on the far right looks like your younger twin!!!!😎
  28. Treydiggity
    LG Dishwasher LDS5040ST Error
    It seems that the door is not latching properly I backed the top mounting screws out a quarter of a turn like sone have advised but nothing then I gently lifted up on the front panel of the door and the thing started working They should have a light for door not latched properly
  29. MrApplianceMatt
    Crosley CW20P6AC washer won't run, just buzzes
    Does it fill with water? What do you mean when you say back of the washer? The buzzing sound could be coming from a faulty water inlet valve as they are just electromagnetic solenoids mounted to the inside of the rear wall on the right hand side.
Important Information
