  2. Manufacturer: LG/Kenmore Type of Appliance: Dryer Model Number: 79681563910 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes The Start button “beeps” when energized but doesn’t start the motor. Thank you Captain. Tomorrow is fine!
  3. Manufacturer: Ge Type of Appliance: washer Model Number: gtw490acj6ws Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes I
  4. Today
  5. Captain Dunsel
    Service Manual needed
    Already a tech sheet is in the download section. Uses the same tech sheet as this model: Uses this Tech Service Tip:
  6. Yesterday
  7. Are the bulb mounting clips all there and not missing/bent? If the sensor bulb isn't where it belongs, it will act weird. Also make sure the flame spreader on the underside of the oven bottom (top of the burner?) is there and not warped. I think I'm out of ideas now. 8-)
  8. Here are the service bulletins: Get an error code e200 when trying to upload the manual. Will try emailing it to you.
  9. vee8power
    Right here, waiting for approval:
  10. Manufacturer: Electrolux Type of Appliance: Refrigerator Model Number: FGSS2635TD0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES NO FILES
  11. FishDontKno
    Delight
    Forum welcome bright, In circuits, gears, I delight, Appliance fixer's light. 🖖
  12. No sweat! Yeah, it's just so odd, I thought for sure it was going to be a homerun installing the new t-stats but they didn't do anything, feel like I'm losing my mind, ha.
  13. I think so. It' been a long time. There might be an adjustment screw down the center of the knob shaft below some paint you need to scrape off, but if you recently replaced it, I'd be inclined to order another one and send it back under warranty. It's off by a lot. Sorry I'm not more help. I haven't had to calibrate thermostat in a really long time.
  14. Son of Samurai
    LG Service Manual Request WM3555HWA/00
    Brother @Vance R, do you have anything for this?
  15. Thanks Terry! Yeah, so I did indeed install a new thermostat but the problem remains, very strange... No issues with the knob. And I have the opposite issue in the left hand oven- temps are about 50-100 degrees too cold. I also changed the thermostat in that one and the issue is the same... Are these t-stats able to be calibrated?
  16. The new burner fixes a problem they had here only part of the "U" shaped burner would ignite. From the parts diagram, it looks like it uses a mechanical thermostat, so if you're sure it's a lot too hot, about all you can do is replace the thermostat. Or if you're adventurous, try calibrating it. PS. Make sure the knob isn't damaged or loose. I think it had a metal insert that would sometimes come out.
  17. Hello and thanks in advance, all! My dryer failed to start on Tuesday, and I can't seem to narrow down what is wrong - I'm a fairly capable handyman. All thermal fuses and thermostats I can see have continuity - I had two round ones on the heater box and a longer plastic one, another closer to the fan and lint duct, and a thing with 4 poles, one set had continuity, the other read 7.5Kohms, if I recall correctly. Belt is on the motor pulley and is intact. Door Switch functions as it should. Start button / signal select switch is good. (Continuity when pressed.) 240 volts available at the plug, 120 from each line, so neutral checks out too. I thought I was gonna crack this thing open, find a failed thermal fuse or thermostat and replace it, but I'm stumped and about ready to drag it back into the house and plug it in again and see if it was a fluke (Not enough room in the laundry 'hall' to work on it.) Am I missing something major or obvious? I'm hoping it's not the timer assembly, but not sure how to test that guy. Thanks again! --Matt
  18. Thanks for that, unfortunately the main problem is the oven is consistently 100-150 degrees too hot. Completely stumped.
  19. until
    All Appliantology tech members are invited to join in this workshop on all things Appliantological: bidness, customers, tools, troubleshooting, flavorite brewski, whatever. Webcams and microphones are open and live! This workshop is also a great time for any students at Master Samurai Tech to bring any and all questions about the coursework. We're happy to walk through any concepts you're having trouble with. Think of it like office hours with your teachers. If you have a specific appliance problem you'd like us to talk about, post it here! We need a problem statement and a PDF of the tech sheet or schematic so we can all see it on screen share. If you have a PDF that isn't already in the File library here at Appliantology, send it to us by attaching it to the contact form. Also, follow this Calendar Event so you'll get notified of new posts here. Look for the "Follow" button either at the top of the topic on desktop or below the topic on mobile. Who: This workshop is only available to tech members at Appliantology. When: Saturday, April 27 @10:00 AM Eastern Time. Where: Online via Zoom How: Click here to go to the forum topic with the registration link. If you're interested, register now. Arrive a couple minutes early to make sure your connection is working. Set a reminder for yourself for this workshop so you don’t miss it. And check out past workshops here: https://appliantology.org/announcement/33-webinar-recordings-index-page/
  20. How does a dryer dry without a vent? Why is there a sealed system in this dryer, just like what you would find in a refrigerator? How well does this model dry clothes compared to a conventional dryer? All of those are questions we answer as we explore Whirlpool's hybrid heat pump dryer. In this thorough rundown of the machine's key systems and components, we cover topics such as: The function of the sealed system in this heat pump dryer How this dryer condenses moisture rather than venting it out Comparing the the heat produced by this dryer vs. conventional dryers Common customer concerns that you need to know how to address Key installation specifications that can severely impact the efficiency of this dryer How the compressor runs on 240 VAC and why ...and more! You can watch this full workshop recording for free and learn all about these topics right now! Just click play below and start your journey. Interested in more of our technical training workshops? Click here to see the full index of 100+ hours of training videos. These are viewable only by premium tech members of Appliantology -- click here to become one today! If you're looking for appliance repair training, look no further than Master Samurai Tech. We have courses that teach you schematic reading, troubleshooting, motors, refrigerators, washers and dryers, ovens and ranges, and more.
  21. Electrolux and Frigidaire Refrigerator Thermistor Conversion Chart Temperature & Resistance View File Pub RFTT2414 Submitter Captain Dunsel Submitted 04/18/2024 Category Appliance Repair Manual Pot Luck Supper
  22. Manufacturer: AEG Electrolux Type of Appliance: Induction Cooktop Model Number: 68031 K-MN Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes
  23. Found this one on a new burner for added ports, maybe to address failed ignition problems.
  24. Viking Range Service Bulletin - New Gas Burner with Carry Over Ports View File Models: SVGIC245, SVGSC306, VGIC245, VGIC305, VGIC305S, VGIC306, VGIC307, VGIC308, VGIC366, VGIC368, VGIC488, VGSC306, VGSC307, VGSC366, VGSC367, VGSC486, VGSC487, VGSO100 PUB TC–0034–SP Date: June 2008 Submitter Samurai Appliance Repair Man Submitted 04/18/2024 Category Appliance Repair Manual Pot Luck Supper
  25. Version 1.0.0
    3 downloads
  26. Captain Dunsel
    Kitchenaid IM Service manual
    Uses the same tech sheet as this model: You should be able to use this service manual: This video comes up for your model:
  27. Manufacturer: Kitchenaid Type of Appliance: icemaker Model Number: KUIX305ESS2 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Under counter icemaker service manual request
