Upcoming Events
27 April 2024 02:00 PM Until 03:00 PM
0All Appliantology tech members are invited to join in this workshop on all things Appliantological: bidness, customers, tools, troubleshooting, flavorite brewski, whatever. Webcams and microphones are open and live!
This workshop is also a great time for any students at Master Samurai Tech to bring any and all questions about the coursework. We're happy to walk through any concepts you're having trouble with. Think of it like office hours with your teachers.
If you have a specific appliance problem you'd like us to talk about, post it here! We need a problem statement and a PDF of the tech sheet or schematic so we can all see it on screen share. If you have a PDF that isn't already in the File library here at Appliantology, send it to us by attaching it to the contact form.
Who: This workshop is only available to tech members at Appliantology.
Where: Online via Zoom
Click here to go to the forum topic with the registration link. If you're interested, register now. Arrive a couple minutes early to make sure your connection is working. Set a reminder for yourself for this workshop so you don’t miss it. And check out past workshops here: https://appliantology.org/announcement/33-webinar-recordings-index-page/
- Past hour
scottjames joined the community
LG Service Manual Request WM3555HWA/00
Vance R replied to Shaphan Hawks's topic in Appliance Service Manual Requests Forum
Here are the service bulletins: Get an error code e200 when trying to upload the manual. Will try emailing it to you. - Today
vee8power started following Service Manual needed
vee8power replied to ShaneK's topic in Appliance Service Manual Requests Forum
Right here, waiting for approval: -
Manufacturer: Electrolux Type of Appliance: Refrigerator Model Number: FGSS2635TD0 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES NO FILES
Forum welcome bright, In circuits, gears, I delight, Appliance fixer's light. 🖖
Heather joined the community
Service Bulletins/Info Related To Oven Temps Viking Range M# VGSC4866QSS
NHTech replied to NHTech's topic in Appliance Service Manual Requests Forum
No sweat! Yeah, it's just so odd, I thought for sure it was going to be a homerun installing the new t-stats but they didn't do anything, feel like I'm losing my mind, ha. -
stacyelliott joined the community
Terry Carmen replied to NHTech's topic in Appliance Service Manual Requests Forum
I think so. It' been a long time. There might be an adjustment screw down the center of the knob shaft below some paint you need to scrape off, but if you recently replaced it, I'd be inclined to order another one and send it back under warranty. It's off by a lot. Sorry I'm not more help. I haven't had to calibrate thermostat in a really long time. -
Son of Samurai replied to Shaphan Hawks's topic in Appliance Service Manual Requests Forum
Brother @Vance R, do you have anything for this? -
Thanks Terry! Yeah, so I did indeed install a new thermostat but the problem remains, very strange... No issues with the knob. And I have the opposite issue in the left hand oven- temps are about 50-100 degrees too cold. I also changed the thermostat in that one and the issue is the same... Are these t-stats able to be calibrated? -
rocase joined the community
Mateus Borba joined the community
The new burner fixes a problem they had here only part of the "U" shaped burner would ignite. From the parts diagram, it looks like it uses a mechanical thermostat, so if you're sure it's a lot too hot, about all you can do is replace the thermostat. Or if you're adventurous, try calibrating it. PS. Make sure the knob isn't damaged or loose. I think it had a metal insert that would sometimes come out. -
Hello and thanks in advance, all! My dryer failed to start on Tuesday, and I can't seem to narrow down what is wrong - I'm a fairly capable handyman. All thermal fuses and thermostats I can see have continuity - I had two round ones on the heater box and a longer plastic one, another closer to the fan and lint duct, and a thing with 4 poles, one set had continuity, the other read 7.5Kohms, if I recall correctly. Belt is on the motor pulley and is intact. Door Switch functions as it should. Start button / signal select switch is good. (Continuity when pressed.) 240 volts available at the plug, 120 from each line, so neutral checks out too. I thought I was gonna crack this thing open, find a failed thermal fuse or thermostat and replace it, but I'm stumped and about ready to drag it back into the house and plug it in again and see if it was a fluke (Not enough room in the laundry 'hall' to work on it.) Am I missing something major or obvious? I'm hoping it's not the timer assembly, but not sure how to test that guy. Thanks again! --Matt
mpk23 joined the community
Thanks for that, unfortunately the main problem is the oven is consistently 100-150 degrees too hot. Completely stumped. -
Appliantology Live Dojo, Saturday, 4/27/2024 @10 AM ET
Son of Samurai posted an event in Tech Training
untilAll Appliantology tech members are invited to join in this workshop on all things Appliantological: bidness, customers, tools, troubleshooting, flavorite brewski, whatever. Webcams and microphones are open and live! This workshop is also a great time for any students at Master Samurai Tech to bring any and all questions about the coursework. We're happy to walk through any concepts you're having trouble with. Think of it like office hours with your teachers. If you have a specific appliance problem you'd like us to talk about, post it here! We need a problem statement and a PDF of the tech sheet or schematic so we can all see it on screen share. If you have a PDF that isn't already in the File library here at Appliantology, send it to us by attaching it to the contact form. Also, follow this Calendar Event so you'll get notified of new posts here. Look for the "Follow" button either at the top of the topic on desktop or below the topic on mobile. Who: This workshop is only available to tech members at Appliantology. When: Saturday, April 27 @10:00 AM Eastern Time. Where: Online via Zoom How: Click here to go to the forum topic with the registration link. If you're interested, register now. Arrive a couple minutes early to make sure your connection is working. Set a reminder for yourself for this workshop so you don’t miss it. And check out past workshops here: https://appliantology.org/announcement/33-webinar-recordings-index-page/ -
[Free Full Video] Learn the Secrets of Whirlpool's Hybrid Heat Pump Dryer...
Son of Samurai posted a blog entry in Appliance Repair Tech Tips
How does a dryer dry without a vent? Why is there a sealed system in this dryer, just like what you would find in a refrigerator? How well does this model dry clothes compared to a conventional dryer? All of those are questions we answer as we explore Whirlpool's hybrid heat pump dryer. In this thorough rundown of the machine's key systems and components, we cover topics such as: The function of the sealed system in this heat pump dryer How this dryer condenses moisture rather than venting it out Comparing the the heat produced by this dryer vs. conventional dryers Common customer concerns that you need to know how to address Key installation specifications that can severely impact the efficiency of this dryer How the compressor runs on 240 VAC and why ...and more! You can watch this full workshop recording for free and learn all about these topics right now! Just click play below and start your journey. Interested in more of our technical training workshops? Click here to see the full index of 100+ hours of training videos. These are viewable only by premium tech members of Appliantology -- click here to become one today! If you're looking for appliance repair training, look no further than Master Samurai Tech. We have courses that teach you schematic reading, troubleshooting, motors, refrigerators, washers and dryers, ovens and ranges, and more. -
Anthony1205 joined the community
Electrolux and Frigidaire Refrigerator Thermistor Conversion Chart Temperature & Resistance View File Pub RFTT2414 Submitter Captain Dunsel Submitted 04/18/2024 Category Appliance Repair Manual Pot Luck Supper
AEG Cooktop 68031 K-MN SM Request
Manufacturer: AEG Electrolux Type of Appliance: Induction Cooktop Model Number: 68031 K-MN Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes -
Samurai Appliance Repair Man replied to NHTech's topic in Appliance Service Manual Requests Forum
Found this one on a new burner for added ports, maybe to address failed ignition problems. -
New Appliance Service Manual added: Viking Range Service Bulletin - New Gas Burner with Carry Over Ports
Samurai Appliance Repair Man posted a topic in Appliance Service Manual Requests Forum
Viking Range Service Bulletin - New Gas Burner with Carry Over Ports View File Models: SVGIC245, SVGSC306, VGIC245, VGIC305, VGIC305S, VGIC306, VGIC307, VGIC308, VGIC366, VGIC368, VGIC488, VGSC306, VGSC307, VGSC366, VGSC367, VGSC486, VGSC487, VGSO100 PUB TC–0034–SP Date: June 2008 Submitter Samurai Appliance Repair Man Submitted 04/18/2024 Category Appliance Repair Manual Pot Luck Supper -
Samurai Appliance Repair Man posted a file in Appliance Repair Manual Pot Luck Supper
Kitchenaid IM Service manual
Captain Dunsel replied to CurlyThePony's topic in Appliance Service Manual Requests Forum
Uses the same tech sheet as this model: You should be able to use this service manual: This video comes up for your model:- 1 reply
- 1
Manufacturer: Kitchenaid Type of Appliance: icemaker Model Number: KUIX305ESS2 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Under counter icemaker service manual request
clarkensz joined the community
Washingpowder joined the community
Kenmore Range 911.4658711 Replacement Bake Element
lilbb posted a topic in DIY Appliance Repair Help
We replaced the bake element (WB44K5012) about 8.5 years ago with what was advertised as an OEM GE part. That replacement has just recently died and it needs replacing again. The GE part is now $35 more at around $55, plus $11.50 shipping for about $66.50 total. I found an aftermarket part that appears to be made by WEN for around $28, no shipping charge as I can get it shipped to a local store for free. Considering the GE element died after only 8.5 years (original by Roper lasted 28 years), is there any point in spending all that money on another GE part? Would there be any issues with using the aftermarket part? I generally try to use OEM, but if it's only going to last 8.5 years with not that much use, I don't know that it's worth it. The original element got heavy usage. -
Vance R started following LG Service Manual Request WM3555HWA/00
Shaphan Hawks posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Lg Type of Appliance: All in one Washer Dryer Model Number: WM3555HWA/00 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Please provide service manual. Getting an error code u5 -
Whirlpool Twist-Tray Ice Maker in Side-by-Side Refrigerators Not Making Ice Service-Pointer View File Pub Service-Pointer-W11491692-Rev A Models: WRS321SDH* WRS325SDH* WRS331SDH* WRS335SDH* Submitter Captain Dunsel Submitted 04/17/2024 Category Appliance Repair Manual Pot Luck Supper
Whirlpool WDF540PADW1 dishwasher service manual request
Uses the same tech sheet as this model:- 1 reply
- 2
Blog Entries
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog1 comment
6 comments
12 comments
Topics
