  2. Son of Samurai
    TAWL650BW1 Estate Washer
    Thanks @Captain Dunsel!
  3. Estate TAWL650BW1 Washer Wiring Sheet View File Pub 3361187 Rev B Submitter Captain Dunsel Submitted 06/01/2020 Category Appliance Repair Manual Pot Luck Supper
  4. Today
  5. tpoindexter
    Appliantology through the Looking Glass
    I am very grateful for this site. I don't know if i'd be repairing appliance today had it not been for the site, and the endless hours you've put in making it work for so many techs. I've received support and encourage at critical times I've needed it. I want to sincerely thank not just you, but Mrs. and Son of Samurai. Thank You.
  6. Captain Dunsel
    Electrolux fridge manual needed
    Uses the same one as this! No service manual that I can find!
  7. Looking for service manual and parts look up please not sure what numbers to give so here’s everything Type: DW16.2 xxl MODEL D5636 ART NO 492570/04 SERIAL NO 61930008 ART NO ASKO 295563121TH SERVICE NO D5636XXLHS/ TH
  8. Check the defrost thermistor resistance using the specs from the tech sheet. If that is good it is more than likely the board.
  9. HI im seeking help in locating the service manual for the downdraft, Model # UVB36SK1SS Serial # zh805435c always I apprecate any help.
  10. Version 1.0.0
    0 downloads
    Pub 3361187 Rev B
  11. Captain Dunsel
    Uploading wiring diagram.Waiting on approval.
  12. Ovidio valentin
    Service manual
    Thank you
  13. Gmaire02
    Dryer
    Thanks
  14. WOOKIE
    Diodes in AC Circuits
    As I learned in MST academy ,triac's are used as switch's. Instead of using a power hungry unreliable relay ,we can use a low power triac to turn on and off loads. We also gain efficiency because it is controlled by a low voltage dc (usually 3 to 5 volts ) and, we don't have to deal with burnt or, sticking contact's.
  15. Captain Dunsel
    Dryer
  16. Gmaire02
    Dryer
    Need tech sheet. Customer having problems with the UI. Thanks
  17. WOOKIE
    triac
  18. Yesterday
  19. Captain Dunsel
    Service manual
    See if this helps.
  20. Thank you guys very much!
  21. Ovidio valentin
    Service manual
    Need service manual. Thanks in advance
  22. Samurai Appliance Repair Man
    A masterpiece, @Son of Samurai! 💪🏻 Pop Quiz: What’s that double triangle thing that Line goes through before it gets to the water valve coils?
  23. Things got a little shaken up around Appliantology this month. There's a new Kendo Master in town, and his name is... @Captain Dunsel! All of you are no doubt familiar with the good Captain by this point -- he's a constant presence on Appliantology, constantly slinging out manuals for folks in need. We're all thankful for everything you do, Captain Dunsel, and your $100 prize is just a small token of that appreciation. Any tech member of the site can become a Kendo Master. At the beginning of each month, we wipe the monthly points leaderboard so that everyone starts on a level playing field. Every time you post a reply to a forum topic or upload a new file to the site, you earn points. Whoever earns the most points by the end of the month wins an Amazon gift card for $100! It's already a new month -- you could be the next Kendo Master!
  24. Thanks @Captain Dunsel!
  25. LG LWS3063ST LWS3063BD Wall Oven Service Manual View File Pub MFL37118346 Submitter Captain Dunsel Submitted 06/01/2020 Category Appliance Repair Manual Pot Luck Supper
Important Information
