  2. @Son of Samurai This turns out to be a Samsung range parts list Posted above.
  3. Captain Dunsel
    Need schematic
  4. Today
  5. Nathaniel Peterson
    Need schematic
    Manufacturer: Frigidaire Type of Appliance: Refrigerator Model Number: LGHT1837LE1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need service manual or schematic please and thank you
  6. Looks like it’s for the stove 😅
  7. Budget Appliance Repair
    Kenmore 417.48102701 Washer won't start/fill/spin - error codes?
    If you have a bad pump relay, that would be a component on the main board. Would have to replace the complete board or check the solder connections to the relay on the board and re-solder if bad/burnt solder joints to the relay or de-solder and source a new relay from an electrical part supply company and replace the relay if the relay points or coil is bad.
  8. Son of Samurai
    Bosch washer 500 series
    Here you go:
  9. Bosch WAW285H1UC/26 Washer Service Manual View File PUB 58300000182833 Submitter Son of Samurai Submitted 03/28/2024 Category Appliance Repair Manual Pot Luck Supper
  10. Version 1.0.0
    3 downloads
    PUB 58300000182833
  11. Bosch WTW87NH1UC/05 Dryer Service Manual View File PUB 58300000220778 Submitter Son of Samurai Submitted 03/28/2024 Category Appliance Repair Manual Pot Luck Supper
  12. Version 1.0.0
    7 downloads
    PUB 58300000220778
  13. Samsung NE59J7630SS/AC-00 Range Parts List View File Samsung NE59J7630SS/AC-00 Range Parts List Submitter Son of Samurai Submitted 03/28/2024 Category Appliance Repair Manual Pot Luck Supper
  14. Version 1.0.0
    1 download
  15. Thank you! Does this mean the drain pump relay can be replaced or do you have to replace the whole control board? This property belongs to my dad so it's not a landlord thing but I can't really rely on him to fix anything so I have to take this matter into my own hands.
  16. That sounds terrible, you could have a bad sensor, or air leak into the ice area, or a bad ice maker if you have ice in the tray it's probably not frozen... I'm not an expert in refrigerators but I would probably shell out for a tech to come by... Hate to to say that... usually condensation is an air leak allowing warmer air to enter the ice area or the sensor is not reading correct.
  17. Manufacturer: Thermador Type of Appliance: Fridge Model Number: T24ID900LP/02 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need a manual/tech sheet for a Thermador Fridge - T24ID900LP/02. Thanks!
  18. dfphoto
    Maytag MAH5500BWW Neptune washer eats bearings
    to myself that seat is damaged and rusted same with the tub and spider, my opinion is you needed a new drum and spider assembly plus you didn't sand the rust and or prep before the new bearing... Its 100% obvious have a water leak its so old of rust... I bought from front load bearings in Colorado he sells Japanese abec5 I believe, I had good success so far 3 years... you didn't mention if you replaced the shocks and springs which I did it all adds up... If I was you junk it the main issue you don't know if the frame is straight as I have now seen in various machines....
  19. dfphoto
    Kitchenaid Double Oven Buzzing
    I diagnosed a jenn air recently had something like this the clock board was fried like Popyeye's
  20. Yesterday
  21. if you really have error 23 it says Drain pump relay on control board failed. Have the landlord hire a tech to verify...
  22. Daniel Rufledt
    Whirlpool dishwasher WDT750SAKZ0
    Lower spray arm split. Saw 2 this week. Sunberg Chicago has 260 in stock
  23. Thanks Captain... You posted this as I was turning in the customers drive. Beautiful timing! I really appreciate it! Tony T
  24. Samurai Appliance Repair Man
    NE59J7630SS/AC Samsung Range Parts Diagram Needed
    Ah okay. @Son of Samurai can you get the parts PDF for this one?
  25. There is no parts diagrams in the service manual for this model
