Upcoming Events
27 April 2024 02:00 PM Until 03:00 PM
5All Appliantology tech members are invited to join in this workshop on all things Appliantological.
Who: This workshop is only available to tech members at Appliantology.
Where: Online via Zoom
Click here to go to the forum topic with the registration link. If you're interested, register now. Arrive a couple minutes early to make sure your connection is working. Set a reminder for yourself for this workshop so you don’t miss it. And check out past workshops here: https://appliantology.org/announcement/33-webinar-recordings-index-page/
- Yesterday
Whirlpool Duet front load washer leak Model WGD9150WW0
Charles Martin replied to martygraw's topic in DIY Appliance Repair Help
Soft water may be an issue if it only leaks during the clean cycle. I had this issue with my brand-new washing machine. Finally, I called the serviceman. He said that with a water softener, there are too many suds, and the suds spill over into the vent, causing the leak. He said only to use a ½ tablet of the washer cleaner (Affresh or other brands). -
Charles Martin joined the community
Chefcurtis joined the community
DionC joined the community
Service manual for frigidaire micro oven combo
Captain Dunsel replied to samedayapprepair's topic in Appliance Service Manual Requests Forum
Uploading parts list and waiting on approval: -
Connor joined the community
never mind. Not following the instructions as closely as I should've: installed 2 nut clamps. One on top of the stem and the old one inside the inner tub. Of course for ~25 yo outer tub, my test run shows a 3mm rust perforation in the base of the outer tub near the drain. I must've completed the perf. when I was cleaning.
F6PDP30S1 fulgor Milano double oven tech manual request
Dwbingham posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Fulgor Milano Type of Appliance: Oven Model Number: F6PDP30S1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Does anyone know how to get manuals or parts for these things? I called there support line, and was asked to leave a message. I seriously doubt that I will ever hear back from them. -
samedayapprepair replied to samedayapprepair's topic in Appliance Service Manual Requests Forum
Hi @Captain Dunsel, can you please forward me part list? thks -
This workhorse has been problem free for somewhere between 22 and 28 years (It was here when I moved in 22 years ago). Things wear out. leaking started, and got more consistent and voluminous. id'd drips from the center spindle. Elected to do stem and bearing replacement. got the bearing done quickly but had to wait a bit for the stem kit (no longer available from Whirl/Mayt -- never happy buying Chinese knock-offs) It showed up & I continued the replacement/installation up through tightening the set screw on the stem. now replace the inner tub, then the washer clamp/cap and finally the nut/screw clamp. But the nut screw clamp can't find purchase of the threads on the stem. You can see in the att. pics even before the cap is placed there isn't alot of TPI visible. Its like somewhere in there I lost a 1/2 inch of height or maybe its time to call a Chinese Knock-off Alert. I've been using two different vids as my mentors. They haven't been perfect but between the two of them it should be a predictable repair. I'm following consistently and disassembled and started again from the stem bellows with the same result Can anyone offer a little guidance on this or tip? thanks. or https://youtu.be/thX1aqNXsYk?t=858
Midea757 joined the community
tonyf7 started following Tech sheet request for Kenmore washer 796.41362.910
tonyf7 posted a topic in Appliance Service Manual Requests Forum
Manufacturer: Kenmore/LG Type of Appliance: Washer Model Number: 796.41362.910 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Y Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Y TY! ref14439 -
GNE25JSKCFSS GE Refrigerator tech sheet/manual please
Dwbingham replied to Dwbingham's topic in Appliance Service Manual Requests Forum
you da man -
Appliantology Live Dojo, Saturday, 4/27/2024 @10 AM ET
Samurai Appliance Repair Man commented on Son of Samurai's event in Tech Training
Captain Dunsel started following KitchenAid KSRG25FKSS04 model ice-maker issue
Captain Dunsel replied to bahram-hermes's topic in Appliance Service Manual Requests Forum
You can use this manual:- 1 reply
- 1
pdrayton joined the community
bahram-hermes posted a topic in Appliance Service Manual Requests Forum
Manufacturer: KitchenAid Type of Appliance: Refrigerator Model Number: KSRG25FKSS04 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES Hi to everyone! I have a KitchenAid KSRG25FKSS04 refrigerator ice-maker not working. Do you have any service bulletin or service manual for this model? -
until
Another tech sheet for us to practice on. This one is another Frigidaire but a refrigerator this time. Model number LGHB2867PF7A. Tech sheet is below. Here are the study questions: What kind of power supply does the augur motor require? When the board supplies one side of the power supply to the augur motor, where does that wire travel before it makes it to the motor itself? What's a reasonable test to do to confirm that the augur motor is capable of running with a proper power supply? If you find the augur motor is not getting voltage, where is your next stop looking for the missing voltage? If the cube crush solenoid is getting voltage, does that mean that the auger motor should be getting voltage, too? Why or why not? -
AMH electric joined the community
waffles joined the community
Samsung Dryer DVE45N6300V/AC Service manual / fast track request
Son of Samurai replied to Kylebravo's topic in Appliance Service Manual Requests Forum
Thanks, Cap! -
New Appliance Service Manual added: Samsung DVE45N6300V/AC Dryer Service Manual
Samsung DVE45N6300V/AC Dryer Service Manual View File PROJECT : DV6300N Model Name : DVE45N6300V/AC Submitter Captain Dunsel Submitted 04/24/2024 Category Appliance Repair Manual Pot Luck Supper -
metrichelios joined the community
BSD joined the community
until
I think you'll nail it. This should be easy stuff for experienced techs. We've had requests from newer techs to practice reading tech sheets and picking out details. @Son of Samurai will be posting a few other tech sheets with study questions. We'll have a troubleshooting party! -
Koi Guy commented on Son of Samurai's event in Tech Training
until
I'll be there with answers. Maybe not correct answers, but answers nonetheless. -
Need tech Sheet/manual
Shaphan Hawks replied to Kennethk123's topic in Appliance Service Manual Requests Forum
I'm familiar with these Daewoo build refrigerators. Let me know if you need help. -
I found it: https://www.dropbox.com/scl/fi/xvr69xly3ckrsn4b20sbp/Service_Manual_Crosley_TMF21_CRD2123NB-CRD2123ND-CRD2123NW_010320.pdf?rlkey=eeghfc12szbm26x0munnuu3p8&dl=0 -
Captain Dunsel replied to Dwbingham's topic in Appliance Service Manual Requests Forum
May have some similarities to this manual: Uses this mini manual: -
Manufacturer: GE Type of Appliance: Refrigerator Model Number: GNE25JSKCFSS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes couldnt find the pub number, either. Thank you, gentlemen -
Sorry no manual. I could only get a parts diagram https://www.dropbox.com/scl/fi/976lvfqyskl6ith7qnk2o/TMF21-FRG21-20-30-CRD21-13-21-CDT21-20-21-Parts-View.pdf?rlkey=z85mqniqgfzln03mpwf7ihggd&dl=0 -
Captain Dunsel replied to Kylebravo's topic in Appliance Service Manual Requests Forum
Uploading service manual and waiting on approval: -
Bosch Dishwasher MOD: SPE53U55UC/30
Son of Samurai replied to Techonamission's topic in Appliance Service Manual Requests Forum
Here you go: -
New Appliance Service Manual added: Bosch SPE53U55UC/30 Dishwasher Tech Bundle
Bosch SPE53U55UC/30 Dishwasher Tech Bundle View File Service manual PUB 58300000176873 Check routine request PUB 56000000157002 Check routine PUB 56000000182236 Error codes PUB 56000000184415 Schematic PUB 56000001210182 Submitter Son of Samurai Submitted 04/23/2024 Category Appliance Repair Manual Pot Luck Supper
Blog Entries
4 comments
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog1 comment
6 comments
12 comments
Topics
until
