We are implementing two-factor authentication for all accounts starting March 13 -- Click here for more info ×
    • 21 March 2026 02:00 PM Until 03:00 PM
      When: Saturday, March 21 @10:00 AM Eastern Time.
When plugged in, machine makes a relay clicking noise every 6-7 seconds, but is otherwise dead- no lights are on, power button does nothing.
This symptom has happened twice before and somehow corrected itself.
  • Replies 4
  • jazzjohn
  • BrianG
  • .israel.
Sounds like a component on the control board failed.
Thanks. Can I get at the control board from the front (without removing the stacked dryer)?
Make sure the washer has the correct voltage. They make a 240vac variant. Check the model/serial tag for the voltage requirements. And yes if you’re changing the power module you will need to unstack the dryer and remove the washer lid.
Oh well.. I was afraid of that!
The washer and dryer plug into a 240v outlet through supplied y type adapter. I found a work-around for getting it to turn on: hold in the power button while turning on the breaker.
Thanks much!
