Skip to content
View in the app
A better way to browse. Learn more.
Appliantology.org - A Master Samurai Tech Appliance Repair Dojo
A full-screen app on your home screen with push notifications, badges and more.
To install this app on iOS and iPadOS
  1. Tap the Share icon in Safari
  2. Scroll the menu and tap Add to Home Screen.
  3. Tap Add in the top-right corner.
To install this app on Android
  1. Tap the 3-dot menu (⋮) in the top-right corner of the browser.
  2. Tap Add to Home screen or Install app.
  3. Confirm by tapping Install.
Upcoming Events
GE Cafe CHS950P2M9S1 induction range: all three left knobs dead, "Please activate your cookware", need tech sheet / service mode
Featured Replies
Model CHS950P2M9S1, serial HA375066P. Cafe 30" front-control induction double-oven slide-in, knob controls, software 05.07.05.24. Range is in Mexico. GE US referred me to Mabe; Mabe's assigned tech declined because the model isn't in their catalogue and they have no tech documentation. A local tech is willing to work on it if he has the tech sheet.
Fault: all three left-side knobs failed overnight with nobody near the range. In the morning knob 1 (front-left) lit and flashed on its own, display showed "Please activate your cookware", Hot Cooktop Surface light came on.
Knob tests, no pot on glass unless noted:
  • Knob 1 front-left: ring lights solid, click every ~3 s, no heat. OFF to Hi to OFF gives "Please activate your cookware" then "Precision cooking canceled", with or without a pot.
  • - Knob 2 rear-left: completely dead. No ring, no message, no response.
  • - Knob 3 Sync (both left): ring solid, cooling fan starts, clicks, no heat. "Precision cooking has stopped" on OFF.
  • - Knobs 4, 5, 6 (warming zone, rear-right, front-right): all normal, heat fine. Both ovens normal.
Already ruled out: breaker off >5 min (no change); cookware (same pan heats on right side); no Bluetooth Precision Cooking pan or probe ever paired; software current; supply fine (both ovens plus two right elements run together); cooling fan runs on a left-side request.
Haven't opened the control panel. Parts diagram for this revision shows LED/Encoder board kit WB27X50966 (one board per side) and induction control WB27X50529.
Asking for: (1) service mode entry to read stored fault codes on this knob/LCD control, (2) what the tech sheet says about the left encoder board vs the induction module for a whole-side failure, (3) anything else in the tech sheet that fits this symptom. Thanks in advance.
  • Views 162
Master Samurai Tech
Account
Navigation
Search
Search
Configure browser push notifications
Chrome (Android)
  1. Tap the lock icon next to the address bar.
  2. Tap Permissions → Notifications.
  3. Adjust your preference.
Chrome (Desktop)
  1. Click the padlock icon in the address bar.
  2. Select Site settings.
  3. Find Notifications and adjust your preference.
