Bosch Nexxt 500 WFMC3301UC/04.
Andrsheep
Hello. I'm looking for the service manual for a Bosch Nexxt 500 clothes washer, model number WFMC3301UC/01.
Thanks.
  • Replies 6
  • fluteycat
  • Andrsheep
I PMed you the download link. Good luck!
May I have a copy as well? I keep getting error 04 on my machine. I opened the front panel and cleaned out the drain pump, it had a bunch of pellets from my son's pellet gun, and lots of sandy grit, put it all back together and I still get the same error.
Thanks,
Judy
I sent it to user [user=50012]c5[/user] who PM'd me...
If you need it, I'll need your email address...
just noticed.. the manual is for the WFMC3200 & WFMC6400
Guest
This topic is now closed to further replies.
