Maytag MAH6500A Front Laod Washer
mundydj
Washer won't drain, "nd" code.  Happened before (when warranty was still active) and control board was repalced.  Need diagnostic steps to determine if problem is the same.  (Already checked, pump is not blocked, never turns on)
  • mundydj
  • hvacdrd
