  • Announcements
      On-demand appliance repair training videos for Professional Appliantologist members Over 30 hours (and growing!) of original, high quality appliance training webinars developed and given by yours truly are at your fingertips, on topics you won't find anywhere else. Fill in those knowledge gaps, strengthen those areas of uncertainty, and boost your skills. Watch on mobile or desktop at your convenience whenever, wherever.  Ultra Short Primer on Basic Electricity, Circuits, Ohm's Law, and Schematic Reading (Length: 1:04:48) Basic Refrigerator Troubleshooting (Length: 1:10:45) Schematic Reading Workshop, 10/2015 (Length 1:19:08) Troubleshooting Strategies for Computer-Controlled Appliances (Length: 48:34) Semiconductors and PN Junctions (Length: 1:04:37) Appliance Temperature Sensing Devices & Technology (Length: 1:27:33) Voltage Measurements, Meters, Ghost Voltages, and Triac-controlled Neutrals (Length: 1:29:32) Troubleshooting with Tech Sheets, Part 1, 4/2016 (Length: 1:09:26) Troubleshooting with Tech Sheets, Part 2, 4/2016 (Length: 1:21:11) Tech Sheet Review, 4/9/2016: Bosch Speed Cooker, Amana Refrigerator, GE Glass Cooktop Range (Length: 1:22:58) Pulse Width Modulated (PWM) Switches used in Samsung Switched Mode Power Supplies (SMPS) (Length: 27:07) PWM Computer Cooling Fan in a Whirlpool Refrigerator (Length: 14:53) Understanding AC Split-phase Household Power Supplies (Length: 52:41) Troubleshooting a Samsung Electric Dryer without Disassembly using Live Tests and the Schematic (Length: 22:47) Troubleshooting a Bosch Dishwasher No-Heat Problem using the Schematic and Live Tests (Length: 15:38) Linear Motors and Linear Compressors (Length: 55:54) Bi-directional PSC Drive Motor Systems in Whirlpool VM Washers (Length: 56:52) Appliance Service Call Structure and Troubleshooting Strategies (Length: 1:00:16) The Ten Step Troubleshooting Tango and Workshop Exercises (Length: 1:35:39) Troubleshooting Ten-Step Tango Advanced Workshop (Length: 1:32:06) Ten-Step Tango Troubleshooting Workshop: Refrigerators (Length: 1:35:57) Whirlpool Duet Washer Schematic Analysis & Whirlpool Dryer Moisture Sensor System (Length: 1:03:04) Neutral Vs. Ground, Inverter Microwave, Digital Communications, Loading Down in DC loads, and more! (Length: 1:14:45) Gas Oven Service Call After a Parts Changing Monkey (Length: 36:04) AFCI and GFCI Circuit Protection Technology (Length: 41:26) Troubleshooting Samsung Refrigerators and more (Length: 1:29:58) 3-way Valves and Dual Evaporator Refrigerators (Length: 1:15:45) Split-Phase Compressors and PTC Start Devices (Length: 1:11:57) Gas Dryer Ignition Systems (Length: 53:50) Refrigerator Sealed System Thermodynamics, Part 1 (Length: 43:07) Refrigerator Sealed System Thermodynamics, Part 2 (Length: 1:09:09) Refrigerator Sealed System Thermodynamics, Part 3 (Length: 1:11:56) Refrigerator Sealed System Thermodynamics, Part 4 (Length: 37:45) Refrigerator Sealed System Thermodynamics, Part 5 (Length: 16:35) Appliantology Peer Group web meeting, Feb 25, 2018 (Length: 1:47:30) Appliantology March 2018 Peer Group Meeting (Length: 1:59:58) To access these webinars and all the other info-goodies here at Appliantology, become a Professional Appliantologist today. If you need cost-effective, time-flexible, state-of-the-art appliance technical training, check out the Master Samurai Tech Academy.
    • Son of Samurai
      [Webinar] Appliantology Peer Group   04/24/2018
      Bring something you'd like to share with your brethren in the craft: it could be photos, a tech tip, new insights gleaned from recent training -- anything having to do with the business or technical sides of the appliance repair trade. If you've got something to show, we'll let you share your screen and give you the opportunity to teach us all something new. And of course, Team Samurai will be there to answer any questions you might have about how to use Appliantology.
woofwoofgrrl
Need Water Softener Recommendations
woofwoofgrrl
I am preparing to buy my house a water softener.  I am at a total loss as to what I should get.  Do I go with the expensive "service" companies like Kinetico or Culligan? Or do I get a brand sold in one of our local plumbing supply places or a Sears/Lowes/Home Depot special? I have hard water (around 8-10 gpg)  that also has iron in it that has been treated with "Iron Mag" by the water department.  The iron comes out of solution when we're in the jacuzzi tub and leaves a lovely bathtub ring. Therefore I would ideally like both problems -hardness and iron- treated.
A few other questions - how do I decide how 'big' of a softener to get?  We are a 4 person, 2 dog household, with a soda fountain to satisfy my Diet Coke addiction.
We have a household in-line carbon water filter already, should we keep it and if we do, does it go before or after the water softener?
Thanks so much!!!
Christine
mark mac
You want to keep the house filter before water softner, the water softner should take care of harness and iron, go to lowes or sears, pick one up pretty easy to install,there rated by gallon use they should be able to pick right one for u
telefunkenu47
I second thst. You just cant beat the sears/stayright water softener for the money. There a lot of sharks out there, so beware.Try to find a water treatment outfit where the owner actually has a degree in chemical engineering or something like that. Have the water tested by an independent lab that isnt trying to sell you something. You cannot test for arsenic etc in the home, or out in the van for that matter, so if they do, tell them to leave, or run for your life. good luck
davidg
Your water is not that hard. This has a bearing on the size of water softener you need also.  I would advise treating the irom first the hardness second and then the carbon filter. Iron lessons the ability of the water softener so treat iron first always.  the carbon filter is just for taste and odor, you don't want it full of iron or hard water; you will just be changing the carbon way more oftern than needed.  Sears is as good as any out there and service is usually cheaper; make sure you have qualified techs in your area b4 purchase at sears. Good luck
certified tech group 51
Too late to get into the game?? we use a Sears model 625.342502 water softner Hi -capacity 50 With two filters  ( before w/s ) run parallal, model 625.34601, filters are rated to 10 microns ......   Morton water softener pellets with rust remover...... We are on a well , three homes,  total 6 people and total of three dogs......I have been to homes that have the complete systems, prices are $3000 to $ 4000 parts and labor.......that is out of my range..... the system at my place has been in use since 1989, just change filters once  a year  and add pellets as needed, check once a month...... If we  use  regular pellets not the additive rust remover, in only a few weeks, the rust color is into everything, orange shaded work shirts, bath tub ring,  toilet,  coffee pot, orange shaded dinner plates..............................
Buckeye310
I have kinetico. My first one lasted over 30 years. I recently bought a new one for about 2400 installed. It's smaller than the old one, but it also is using less salt. And it works great.
