hot water heater won't lite
stevek
My water heater pilot wasn't lit, so I replaced the thermocouple. It still wouldn't lite. I replaced the gas control valve. It was a valve that has two wires for an igniter, it wouldn't stay lit till I wired the two wires together. Then it would lite. A couple days later and it is out again and won't lite. The control valve was a robert shaw identical to the old one except for the two wires. The water heater has black burn marks on the outside near the opening at the bottom. Any thoughts?
water heater model number ?
old Gas Valve model number ?
new Gas Valve model number ? (why did you buy that one ?
I don't have the numbers here, I bought it because it was the only one they had, and also the model number was the same except for an additional letter.
