Service Manual for Fisher & Paykel E331T Fridge
lilpil
Would appreciate it if I could be pointed to the right direction to find the service manual for the F&P E331T fridge.
I have the fridge flashing a fault code and beeping alarm going off at me every 3 days when I disarm the last alarm ring and need to know whether I can get this sorted out fairly easily or I need to call in the big guns for backup.
Thanks in advance.
  • Replies 1
  • lilpil
