Samsung Dishwaser
hart
  • hart
Hard time finding that one. What problem are you having: leaks, odors, starts by itself, just plain sucks...?
Need drawings to replace door hinges as the door will not line up properly. Very difficult to find tech info. I called Samsung and they would not help at all.
