GSH22JFTAWW & WFW9600TWO1
Guest Bobo385
Had 2 difficult machines this week really need the service manuals to get a better grip on them. Your manuals in your stash are gerat and have helped me more than I can tell you. You and this site are the best
  • Replies 4
WFW9600TW01 Tech Sheet
GSH22JFTAWW may be similar 31-9072
that model seems to be in the date code range of MotherBoard service bulletin
links PM'd
30-9072 Is similer only diff I see is temp adjustments moved to dispenser on freezer door. Changed water valve because had no water at the dispenser valve was bad had votlage and no water coming out of the valve. The water worked a couple of days and stopped then started to work again then stopped all together.
The problem I have now is no water at the dispenser. Disconnected line at the bottom of freezer door and get water when I call for it. Only thing I can figure is line is frozen in the freezer door. I have the customer turning off the box for 2 days to defrost the line. Any info on how to disassemble the dispenser. Any recall notices by chance coverd under warranty. customer not to friendly
