Grasshoppers may no longer start new topics in the Suggestion Box
Well, it was a noble experiment: allow all participants here at the Samurai School to make suggestions for its improvements. Problem was that Grasshoppers kept coming along and starting appliance topics here. They just aren't familiar enough with The School to give them that kind of access. So, to submit a new suggestion here, you need to be Apprentice or above. Saaaweee!
Yeah, it's so sad... and to think I had something special planned for my delectable leetle grasshoppahs...
Looks like I slipped under the wire. ;)
No slipping at all-- you're not a Grasshopper! :)
i know exactly what it is...... ice is frozen water
Model number? Kenmore... I think.
john63: "What's the problem that you're having?"
Customer: "I don't know,it's not working right".
john63: "Can you elaborate more?"
Customer: "Just that it ain't working the way it should".
Sadly---this conversation is not a hypothetical scenario...
Guest RJ Kanary_old
It's the same way in the Automotive Service industry from which I was forcibly retired by disability. "I can't describe it, but ever since you worked on it, it just doesn't seem right ".
RJ
  • 4 weeks later...
Trust me Gentlemen (and ladies), it's in any repair industry. Working in computers you see this very often, and there are many things that can cause it to "not work right." The sad part is when you do a search and destroy for trying to find problems, you'll find lots and none of it will resolve their issue.
