Purdy Pitchers
The forum allows you to set not one, but two, count 'em, two photos. One is an avatar that appears in posts you make. The other is a photo that appears in your profile and your control console, upper RH corner. They can be the same or different, mix and match, go nuts. Or not.
To set 'em: Upper RH corner > My Settings > Profile tab: Change Photo & Change Avatar selections in the LH column.
  • Replies 0
