Thermador REF30QW Range
lambo87qv
  • lambo87qv
The clock/temp display is very dim. I read in another post that replacing the electrolytic caps will fix the problem. BTW- thanks for the manual. I wasn't sure how to get to the control module.
...read in another post that replacing the electrolytic caps will fix the problem..
let us know if that fixes it ..
