sub zero manual/parts list
catservices
I'm working on a Sub-zero ref. Model is 632/0. I'm in need of the service manual and a parts list. I believe I need the control but I would like to look through the service manual. Past that I dont have an exploded view or parts list for this model. As always thanks for your help.
  • catservices
I'm looking at a model 632/0, serial M1713810. Thanks again, I should have been smart enough to post all the info I had.
