Who Made my Kenmore?
Yeah, I know about those "breathers."
Enjoy! :tokin:
  • Replies 72
Anyone know what Kenmore code: 693. is (Williams by anychance?)
It's a freestanding unvented gas heater: 693.358530
Hmm... what do you reckon, what kind of breath fresheners did the guys use, who made the Toxic Avenger movies?:D
I don't believe I've run across a 693 yet. Maybe I have but don't remember.:huh:
Thought could tell by the part numbers, but do not recognize the part numbers source either...on the Sears site....
The only picture I have is from the internet
CLICK HERE for the Ebay listing with a picture.
This auction seller is the same company that I orginally knew to have this heater, (without going thru the auction their normal price is only $110.00 + shipping).
This heater is unvented and uses the ODS, (oxygen depletion system), pilot. Only needs a gas line to hookup and operate.
Three postion gas valve, Off/Lo/Hi, 0/15000/30000btu - No t-stat.
I have a customer that is looking for a small cheap heater to heat just one room of the house, this is the best I could find so far.
Anyone here have any feedback on this??? $110.00 seems like a pretty good price, depending on how much shipping whould be to get it from Lebanon, IN to Eureka, CA.
I thought it appears to be a Williams, but like Pegi said, the part#'s on the Sears sites don't look like Williams part#'s, (I don't recognize them either).
willie thats a good price and thats a nice heater. I have one and I also repair them
during the hotter months they tend to get dust in the pilot ods chamber which can be easily flushed with a little rust buster other than that they are fine heaters
Thanks for the feedback ApplianceMan......
Do you know what kind of price these would have retailed for when new?????
one more thing... these heaters cant be converted from one gas to another without it costing plenty so if you are buying a heater like this you need to know exactly which gas you are gonna have and make sure the heater is compatible.
What does ODS mean?
An unvented gas heater will consume oxygen and give out its exhaused gas in that room.
Don't think that it is safe/legal to use unvented gas heater in an "air-tighted" and well-insulated house in US and Canada!?
ODS means( oxygen depletion system) when oxygen is thin in the room the ods reduces the pilot flame and the safety magnet cuts off the gas and the heater is turned off, this keeps ya from dying from no oxygen. now , how well does it work? some say its ok others have doubts . my opinion this is a fine heater
Thanks for the explanation.
It still gives out combustion exhausted air which is mainly composed of carbon dioxide. If the combustion is poor, carbon monoxide will be generated and this is extremely dangerous. I think that it is not recommended to use unvented heaters in houses at all in Canada.
It isn't recommended to use un-vented fuel-burning heaters back here in northern Europe either, no matter what fuel... houses are quite tight. But, the ODS should shut the heater down before O2 will be depleted so that CO will form. If it is a catalytic heater, it should produce mainly CO2 on quite low oxygen. Some NOx of intake air will be used in the process too.
Don't remember where I read this, but some fire extinguishing gas mixture was designed to lower the O2 content of air down to some 11%... barely enough for human life for a short while, but non-catalyzed burning of most carbon compounds would require 16%... correct me if you find correct percentages somewhere.
What does ODS mean?
You could be very well correct on it not being legal to sale an unvented gas heater in some states in the US, (California , being one of them -- Johnstone Supply Co. has some unvented gas heaters listed in their book and it says:
"Suitability for installation in your area should be verified with the local code authority. These products are not approved for use or sale in all or part of the following states: Alaska, California, Colorado, Massachusetts, Minnesota, Montana, New York and Utah.")
  • 1 year later...
The Home Smithy
(Bows deeply) Please pardon my intrusion, Great Masters. I believe I may be able to offer some small bit of enlightenment on this subject.
These are the halon extinguishers. Humans can survive in a halon atmosphere long enough to exit a building, but not much more. They were initially designed as a stop gap type system to be installed in older movie, and theater houses, with inadiquate exits to bring them up to modern day building, and safety codes. Fortunatly they were never approved for that reason. They are however installed in many museums, art galleries, libraries, and other buildings that house important documents. Were it not for the halon systems the documents would be destroyed by the water, or even the Co2 units in use prior to halon.
Hope this helps.
Humbly offered to those who would accept my paltry tidbits of wisdom.
Apprentice"Smitty" (bows deeply)
  • 2 years later...
I no longer (unfortunately) have my old Kenmore appliances, so I have no number to go by.
It is time to yet again replace a Kenmore appliance (washing machine, not quite 6 years old...fridge is already in a landfill somewhere--didn't make it to 6 years)
Does anybody by chance know who built their appliances prior to say, oh about 1986 (when they were still good)?  I know that Kelvinator used to manufacture their refrigerators, but my knowledge ends there.
Any help would be appreciated.
[user=71311]Maggie61[/user] wrote:
It is time to yet again replace a Kenmore appliance (washing machine)
Good chance the washing machine was Whirlpool. Washing machines were the beginning of the Sears/Whirlpool courtship way back when...
(There's trouble in Paradise these days)
