Electrolux - Washing Machine EIFLW55HIW
Tuan Thai
  • Tuan Thai
  • kdog
Thanks for all your help. Turns out, nothing is wrong with the washer. I get error code E11 (Fill time too long).
Tankless water heater output is only 3GPM at the tank and at the washer outlet, it's only 2.5gpm.
Tankless is a Noritz NR98 (N-0751M) Series Residential Water Heater. The specs for the water heater suggests it should output 9.8 GPM; but it's giving me only 3 GPM at the output.
I guess my next step is to figure out why I"m not getting the advertised output on the Noritz.
