Whirlpool Commercial TL Washer Model# CA2751XSW4
Adirondack Bob
Does anyone have the service manual for Whirlpool Commercial Top Load Washer Model# CA2751XSW4 Serial #C83703627 Thank You, Bob
  • Replies 4
  • Adirondack Bob
Me no gotty. You come up with anything, Reg?
You rock, Reg! :rocker:
Thanks Reg and Samuraii, Problem solved! There was a broken wire in the plastic connector at the motor. It was the red wire. Motor just hummed. Pulled pin out of connector, re-crimped wire, works as good as new. Thanks again guys, Bob
