Elecrolux FL Washer Model# EIFLW55HIW
Adirondack Bob
Hi All, Does anyone have the service manual for Electrolux Front Load Washer Model# EIFLW55HIW ? Thank You, Bob
  • Adirondack Bob
  • OFS
  • 5 years later...
1 hour ago, OFS said:
Could this be posted vs sharing PM? Thanks
It's already in the Downloads section. Reg gave the PUB number in his reply.
On 10/12/2011 at 2:27 PM, RegUS_PatOff said:
137022700.pdf
Just search the Downloads using the PUB number, 137022700, and you'll find not one but three copies of the tech sheet.
