ge gsh25jstass water solenoid
bmmc
water in door inoperative.replaced water/ice maker dual solenoid in rear which i can hear operate when water in door lever is pushed.suspect solenoid in door is defective as i do not hear it operate.no mini manual.question is how to gain access to the solenoid?does the plastic trim just pop off?don't want to tear anything up.service or mini manual would be a great help.
Solenoid is in back, in the compressor compartment. Follow the water tubing to the fridge and you'll find it -- it connects to the water valve.
Water valve part link w/video on how to replace ==> Water Inlet Valve
I believe we have a communications failure captain Samurai!!!!!!
Our apprentice said he replaced the water/ice maker dual solenoid in back and can hear it buzz when water dispenser is pressed in front so thinks there's a solenoid in the door that isn't operating.
BMMC, the only solenoid in the dispenser unit in the door is the solenoid that opens the ice chute door, has nothing to do with the water dispenser.
Sounds like the famous GE frozen water line in the door to me...... Probably going to need one of those GE dispenser heater kits.
thank you for correcting me concerning the function of that solenoid in the door.could you enlighten me more about the ge dispenser heater kit?
