GE fridge TBX25PCXCRAA manual
RedToryTy
To Sensei Reg,
Please send the GE fridge TBX25PCXCRAA manual.
Domos in advance,
The Red Grasshoppah
  • Replies 4
  • RedToryTy
GE model numbering :confused:
I can't find a manual for that model,
but seems to be just a mechanical Cold Control
mechanical Defrost Timer
What's the problem ?
The method for accessing the evaporator coil/defrost heater.
Reg, I've only done one of these; do you have any experience about accessing the evaporator system?
