I have an eco-therm MV120 direct vent propane heater that will not stay lit.
cbakes
This unit will lite and stay lit for 10 minute to an hour and just quit. I have a nearly full propane tank. Thinking possibly a bad thermocouple any ideas chuck
  • Replies 8
  • cbakes
  • kdog
  • jumptrout
Does it have a Pilot Light ? Probly electronic ignition
Yes it does have a pilot and when the main burner quits the pilot also goes out
If you follow the Maintenance Instruction in the manual provided by RegUs-PatOff you will most likely correct your problem.
I changed the pressure regulator on the propane tank and heater has run for thee days now with out any problems. Thanks to those who responded and special thanks to RegUs-PatOff for the link to manual.
Good Job posting the outcome ! Was the regulator you replaced of the same pressure/voulume ? Did you refill the tank at the same time ?
Install a drip leg on the gas supply line at the regulator to keep moisture from fouling the new regulator and causing new problems.
Remember to drain the drip leg yearly.
