Bosch WFMC3200UC service manual request
Larry Altenburg
I've tried everything to get the fabric softener to dispense and not fill with water. I've replaced the dispenser unit, and ran the washer with no detergent or softener, and the compartment still fills with water and remains full after the cycle ends.
Help! TIA
  • Replies 1
  • Larry Altenburg
