GE TFX25JRBAAA SxS refer
Manuel please.
This fridge has 30*F on top of the ice maker, ...40*F in the middle of fresh food side.
No ice is being made was the complaint. ( its too hot in the freezer for the ice machine to cycle)
thanks
  • Tuco
Compressor is controlled by the Freezer Control
Is the Compressor running "forever" ?
may need to see the frost pattern of the Evaporator Coils in the Freezer
maybe
31-5245 1994 30 SxS TFH TFX.pdf
link PM'd
Thanks Reg.
Very long evaporator. Frosted 2/3 from bottom up. Temps 30*F at the ice macker. 10*F lower in the freezer. Evap motor is working too.
I think the frig is on a slow death.Its over 10 years old.I recomended they go shopping , and also gave the name of a "sealed system" guy if they want to go that route.
