Thermos #430 Christa Coffee Carafe disassembly
djgiesbrecht
djgiesbrecht
Yeah, I know it's not electrical, but does anyone know how to disassemble this plastic coffee carafe from Thermos? There is something liquid sloshing around between the layers. There appears to be a rubber gasket at the top, but the disassembly point would seem to be half-way down the outside. Does it snap apart, unscrew, or is it permanantly glued?
  • appl.tech.29501
  • djgiesbrecht
  • Kauphy Mon
i think they are permantly glued....not absolutely sure though...i do know they dont offer any parts though.
  • 3 years later...
Four years after you posted your question, no doubt "I'm a day late and a dollar short" so to speak.  My Christa #430 also suffers from interior sloshing from time to time.  In fact the carafe does come apart;  the outer case screws apart about one inch above the bottom of the carafe allowing access to the glass vacuum bottle and rubber gasket for cleaning.  I suspect water gets inside from leaving the carafe immersed in the dish water when cleaning. but I suppose coffee may get in there too if the rubber gasket isn't properly seated or is starting to deteriorate.
If you still have your Christa #430 and still haven't managed to get it apart, get your haz-mat suit on and have a go at it.  I wonder what's growing inside!
