Begin your journey to appliance repair mastery...
llky
Maytag SAV5710AWW noise
7 posts in this topic
Have this Maytag washer model no SAV5710AWW that is making a loud banging noise in the spin cycle only.It fills, agitate good with no noise.But when it goes into the spin cycle it makes a loud banging noise.What could be causing this noise?It will spin but makes this loud banging noise,kinda like something is wobbleing around.
Thanks for the reply and the help.
Does anyone have any info or help on how to check out and change the helix and pulley?
A very easy repair, just one bolt holds pulley and helix in place,remove belt from transmission pulley, remove bolt, remove old helix and pulley and reinstall new helix and pulley, (put a little silicone lube on new helix and pulley mating surfaces).
Thanks for the info.I'm going to check out the replacement of the helix and pulley.
Check the friction/snubber ring for wear..........piles of fine white shavings????? paint wearing off from under the ring???? See Repairclinic for details.......P/N 40037401
