BOSCH DRYER WTA3510US Not heating
APPLIANCE DEAN
The heating element in this unit was fried for sure I visually inspected the coils and they were damaged. There was a nail stuck in i causing the damage. I Checked for proper voltage at the heating element and was only getting 120.00. I put in a new control board and the unit now turns on but no heat. The timer counts down but it's not heating. Please help as these Bosch parts are expensive.
  • Replies 5
  • APPLIANCE DEAN
  • kdog
  • Adirondack Bob
You have 240 supply? I think those plug into washer and there are some cartridge fuses involved - if I recall they're oddball 16A fuses
Click on Pic:
I will check this but I'm pretty sure I was getting 240v past the fuse but I may be off.
Just a thought. On the Heating Element Assembly (Item #467462-Manufacturer Number 265676) there looks to be a Manual-Reset Thermostat. That may be tripped?
  • 4 months later...
keyed wire connector on the control board fit in the wrong slot. The heating element was only getting half of the power.
