PDS18SBMALBS Service Manual
richseattle56
  • richseattle56
GE Bottom Mount Fridge..
mechanical controls, no MB
I don't think there's a service manual for that one
What's the problem ?
richseattle56
Customer says its not cooling properly. I haven't gone to look at it yet. Im guessing a defrost problem.
richseattle56
I just went out on another call for this model. Evaporator fan bad. From the parts breakdown it looks like the evaporator fan is accessed through the bottom of the fresh food section. Am I right?
Thanks for any help.
