Kenmore 565.8824581 microwave
jb8103
So it's actually a Sanyo. It's also just plain dead. Maybe that line fuse? I dunno, never have touched a microwave, but this belongs to my best client, can't say "no".
Could be one of the door switches stuck and caused the fuse to blow - helps if you shut off or use pause button when opening door as opposed to pulling open and having switches stop it. Always a good idea to tape spare fuses inside cabinet while you have it apart (for next time).
M/W's are basically the same, here is a general diagnostic chart
  • Like 4
